Intermittent heating on st220?
Basicly I have the heating on 28 degrees but some times the heater will just start blowing out cold air for so long eg 5 mins then I will just go back to normal.
Anyone know what this could be? The electronic heating control?
It's a 54 plate mate and it'll do it even when I first start it up and leave it running for 5 mins, it'll just stay freezing cold then just come on full whack?
mine does it too, unless you put it on full hot it tends to vary between lukewarm and fairly hot
it only started doing this after the thermostat broke so it could be something to do with a reset on the auto climate control system but this only seems to be applicable to the pre facelift cars with the round dial/button configuration rather than the later ones with no reset on them
there you go
http://www.fordwiki.co.uk/index.php?...iagnosis_Guide
if you can't read the site then this is what it says:
With the ignition switched on to position 2, on the E(A)TC module, PRESS the "OFF" and "FOOTWELL" buttons simultaneously very briefly, then PRESS "AUTO" within 1.5 seconds.
The self-diagnosis which then starts lasts a few seconds. An animated display appears in the E(A)TC display during this time. Any faults found are displayed in the form of trouble codes. Example: First of all, "93" flashes for 2 seconds, then "42" flashes for 2 seconds - DTC 9342. If no faults are stored, then all of the segments in the display are actuated.
Diagnosis mode can be stopped at any time by PRESSING any button on the E(A)TC module.
Note: If the "DEFROST" button is pressed to end the diagnosis mode, all DTCs in the fault memory will be deleted!
Fault Codes
B1200 Any button of the air conditioning system Button jammed/stuck
B1242* Air recirculation flap: fault in the circuit Open circuit/short circuit
B1251 Interior temperature sensor: open circuit Check the wire and the sensor
B1253 Interior temperature sensor: short to earth Check the wire and the sensor
B1261 Sun load sensor short to earth Check the wire and the sensor
B1262 Air distribution flap - defrost fault in the Check the wiring; defrost flap circuit positioning motor
B1263 Air distribution flap - centre vents: fault Check the wiring; centre vents in the circuit positioning motor
B1342 Automatic climate control module inoperative The trouble code is set in the event of failure.
B1676 Insufficient battery voltage Battery voltage not in the range 9 - 16V
B2266 Temperature flap: fault in the circuit Check the wiring and the temperature flap positioning motor
B2297 Heater housing outlet sensor: open circuit Check the wiring and the sensor
B2298 Heater housing outlet sensor: short to earth Check the wiring and the sensor
B2308 Interior temperature sensor for the fan Damaged motor or open circuit motor inoperative
B2516 Blower: fault in the circuit Damaged motor or open circuit
all this info is from talkford's wiki page and nothing i've put together so any big up's should go to them
Fault Codes
Si B
Sep 12, 2015 06:49 AM
cossie09
Sep 10, 2015 06:56 PM
