Help! Huge wobble in porker!!
Old Feb 15, 2014 | 05:33 PM
StephTell's Avatar
StephTell
Default Help! Huge wobble in porker!!
All of the sudden I feel the car juddering when driving over all surfaces.
It's noticable from the driversseat but twice as bad in the passengerseat where you're physically rocked around?!
It feels as if one tyre is completely flat or one of the wheels is buckled.
- All 4 wheels are tightened properly
- Original Porsche 20" wheels
- wheel nuts/studs not broken
- wheels not damaged
- brakes not sticking, not hot
- all 4 tyres at the correct pressures
- not visible damage to the tyres
- no side to side play in the wheels
- no knocking and/or scraping noises
- no juddering in the brakepedal
- no errorcodes
- airsuspension works on all settings, no errorcodes
- adjusting rideheight or suspensionmode has no effect
It seems like it's coming from the passengerside of the car and when I reverse is seems the front wheel is moving up and down??
Any ideas what this can be?
StephTell's Avatar
StephTell
Cayenne Turbo by the way!
Old Feb 15, 2014 | 05:38 PM
saph4be's Avatar
saph4be
Tyre out off shape?
Old Feb 15, 2014 | 05:39 PM
GVK.'s Avatar
GVK.
Driveshaft inner joint?
Twisted (out of shape) tyre?
Would be my first guesses.
Old Feb 15, 2014 | 05:51 PM
StephTell's Avatar
StephTell
The tyre seems to look normal but could it still be shot?
Driveshaft would be knocking and banging around I would think, especially under power?
Old Feb 15, 2014 | 05:56 PM
saph4be's Avatar
saph4be
Tyre problem can be hard to see unless it does it at speed? Driveshafts don't allways make a noise either. What sort off speed is it happening?
Old Feb 15, 2014 | 06:05 PM
StephTell's Avatar
StephTell
It does at any and all speeds....feels like one of the wheels is squared off??
Otherwise car behaves as normal, full power, perfect braking, not a single noise but it physically bounces the passenger up and down it seems??
Old Feb 15, 2014 | 06:20 PM
lecky12345's Avatar
lecky12345
I would swap either front off side to front near side first, then if the wheels are the same size front and back try a front to back change, if the wobble moves you might find a duff tyre.
Old Feb 15, 2014 | 06:21 PM
Churtz's Avatar
Churtz
Switch wheels front to back and see if the sensation changes or feels like its moved to the rear. That'll give you an idea if its tyre/wheel related
Matt
Old Feb 15, 2014 | 06:26 PM
StephTell's Avatar
StephTell
Good advice, will give that a go tomorrow!
Never had this before...weird to feel something so 'extreme' without seeing any damage!
Old Feb 15, 2014 | 06:42 PM
Thrush's Avatar
Thrush
Irritating c........
Check if tyres are directional before swapping N/S to O/S
Old Feb 15, 2014 | 06:47 PM
ste1806's Avatar
ste1806
maybe a tired shock absorber
Old Feb 15, 2014 | 06:51 PM
StephTell's Avatar
StephTell
Is so bad that if it was a shock it should have collapsed....but it's on selflevelling airsuspension wich is working fine...it's perfectly level, you can select all 4 modes without problem as well as all three dampersettings so suspension is not the culprit....
Old Feb 15, 2014 | 07:44 PM
pacificzetecturbo's Avatar
pacificzetecturbo
What about an engine mount or gearbox mount?
Old Feb 15, 2014 | 08:20 PM
StephTell's Avatar
StephTell
Nope, deffo a rolling issue!
Old Feb 15, 2014 | 08:26 PM
slammedorion's Avatar
slammedorion
Matt
Worth checking that some wheels are wider on the rear than the fronts...
Old Feb 15, 2014 | 09:19 PM
brad's Avatar
brad
If you have the optional space saver wheel use that as it's designed to fit on all corners.
Old Feb 16, 2014 | 12:01 AM
beaver rs 88's Avatar
beaver rs 88
in the garage
I bought a car really cheap a few years ago with a similar problem to this the owner had spent hundreds on new hubs bearings steering rack lower arms. Basically he changed everything on the front suspension. I looked at it and found the front tyre on the nearside was egged on the inside. Changed it for the spare and the wobble was gone. Quids in lol. First thing to try if you have a spare imo.
Old Feb 16, 2014 | 07:19 AM
StephTell's Avatar
StephTell
I've got a set of winter wheels, those are 18" rather than 20" so I'll have to swap them all but I guess it's the sensible thing to do before visiting the stealer!
Old Feb 16, 2014 | 12:09 PM
StephTell's Avatar
StephTell
SORTED!!!
Swapped all four wheels for my winterset and the problem is GONE!!!
Checked the summerwheels and found one dodgy tyre: Offside rear seems to be concave over the width of the tyre, especially in one specific place...?
Never seen something like it, what can cause this?
Tyre coming apart or collapsing on the inside?
Glad it's sorted now! Cheers for thinking this one through with me!
Old Feb 16, 2014 | 12:47 PM
clairendave's Avatar
clairendave
Dave not Claire.
pot ole that has caused the tyre casing to start to fail at a rough guess. happened to our daily on the front.
`spotty
Sep 25, 2015 11:41 PM
37
Sep 17, 2015 05:05 PM
Mark Mawson
Aug 31, 2015 07:09 PM
Alloy wheels and ICE for sale
Aug 16, 2015 07:55 AM
