Intake manifold to Turbo Charger breather hose?
Old Feb 13, 2014 | 04:56 PM
surrey_100e's Avatar
surrey_100e
Default Intake manifold to Turbo Charger breather hose?
Hi Guys,
On my turbo i have a union as the following photo shows, this is suppose to be connected to the intake manifold.
1) is the Intake manifold to Turbo Charger breather
On my engine i no longer have the pcv set up as shown, so do i need to have the hose going from the turbo to the intake manifold? What does it do?
Martin
Old Feb 13, 2014 | 04:59 PM
stevieturbo's Avatar
stevieturbo
C**t
Block it up.
Old Feb 13, 2014 | 05:11 PM
surrey_100e
Originally Posted by stevieturbo
Block it up.
That's what I was thinking, haven't seen any other turbo set ups with anything like it. Recon it should be fine then?
Martin
Old Feb 13, 2014 | 07:06 PM
stevieturbo
C**t
If you have an effective breather system and you wish to recirculate back into the inlet tract then you can use it.
This is rarely desirable.....although it would be more emissions compliant than venting breathers to atmosphere.
Although directly into the turbo is the last place I would do it if I did wish to recirculate.
Old Feb 13, 2014 | 07:46 PM
surrey_100e
Thanks for the response.
The engine is dry sumped so the block is sealed and the only breather is at the oil tank end. I will plug it up
Thanks for your help.
Martin
Matt Baxter
Sep 16, 2015 08:30 PM
mrknifey
Aug 30, 2015 11:48 AM
YODI
Aug 29, 2015 05:48 PM
Franko99
Aug 29, 2015 01:38 PM
IAN RS2k
Aug 18, 2015 07:51 PM
