King pin inclination
Old Feb 12, 2014 | 05:19 PM
2Litre's Avatar
2Litre
Default King pin inclination
As title , I have been looking through my workshop manual Vol 1-2 for a Sierra Mk1 Cosworth(3 Door) and cannot find the standard King Pin inclination figures , can anyone shed some light on this?
Or has anyone got any wheel alignment printouts that state KPI along with included angle which is the sum of kPI and Camber.
I really need this info, please take some time and help.
Cheers.
Tim.
Old Feb 12, 2014 | 06:38 PM
2Litre's Avatar
2Litre
Anyone know the finer details?
Old Feb 12, 2014 | 06:47 PM
Sierras dont have king pins.
Old Feb 12, 2014 | 06:53 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
still called KPI Glenn
here's a link Glen https://www.google.co.uk/search?q=Ki...w=1264&bih=627
Old Feb 12, 2014 | 06:59 PM
GVK.'s Avatar
GVK.
Old Feb 12, 2014 | 07:01 PM
fraser9764's Avatar
fraser9764
Can't help on actual figures but surely this is set by the hubs and not adjustable, or am I over simplifying it?
Old Feb 13, 2014 | 05:32 AM
Well what a stupid thing to call it.
Old Feb 13, 2014 | 07:24 AM
2Litre's Avatar
2Litre
Fraser9764 This is as you say not adjustable but on my wheel alignment readout I have KPI 14 degrees 02 minute positive on the left side and 7 degrees 52 minutes positive on the right side!
So I am trying to find out the correct angle and also what would cause this, - whats bent?
Thank for your help and time.
Cheers.
Tim
Old Feb 13, 2014 | 08:58 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Dont forget as youre running a macpherson strut that the top mount will have the potential to drastically effect it.
In theory it could be bent TCA, bent hub, bent strut, worn ball joint, worn TCA inner bush or worn topmount. Or if youre really unlucky, bent subframe or bent shell.
Old Feb 13, 2014 | 09:10 AM
Ben26's Avatar
Ben26
Ill have a look on autodata for ya in a bit. See if it says on there.
Old Feb 13, 2014 | 10:10 AM
2Litre's Avatar
2Litre
Thanks for help and replies, Ben that would be great as I really need to know what KPI should be.
Cheers.
Tim.
Old Feb 13, 2014 | 05:56 PM
GVK.'s Avatar
GVK.
KPI not listed on Autodata.
Load positioning : Unladen
Toe-in (N = negative, toe-out) mm: 2,50N - 2,50P
Toe-in deg: 0°25´N - 0°25´P
Toe-in deg-1/100: 0,42N - 0,42P
Camber deg: 1°21´N - 0°39´P
Camber deg-1/100: 1,35N - 0,65P
Castor deg: 0°52´ - 3°22´
Castor deg-1/100: 0,87 - 3,37
ETIS doesn't go back far enough for Sierras.
Old Feb 13, 2014 | 06:31 PM
2Litre's Avatar
2Litre
Yes I had a look at a garage on Auto data with no luck, the only thing that's left is for someone to post their printouts of 4 wheel alignment? Anyone got one for a three door??
Thanks everyone.
Tim.
Old Feb 15, 2014 | 06:17 AM
2Litre's Avatar
2Litre
Default Alignment printouts
Anyone got a 4 wheel alignment printout for a 3 door stating KPI etc?
Cheers.
Tim.
Old Feb 15, 2014 | 02:48 PM
fraser9764's Avatar
fraser9764
Im assuming that the casor and camber readings were correct, and just the kpi that is out, which would point to the other bits being ok,
can you post the rest of your results? Did the wheel alignment place not give you any ideas?
Old Feb 15, 2014 | 06:12 PM
2Litre's Avatar
2Litre
Yes everything else seems ok-
Left Camber -2 degrees 08 mins
Right Camber-2 degrees 0 mins.
Left Castor 2 degrees 32 mins
Right Castor 2 degrees 40 mins
It's only the kPi that differs the left one(14 degrees 02 mins) looks as I believe a 3 door standard wheel should tucked under the arch and the right one 7 degrees 52 mins KPI looks further out and more in line with arch.
My next step is to change the struts and right spindle (Hub carrier) the alignment people think this might be an issue.
But I really need to know what the standard KPI for a 3 door is I have seen a couple of printouts for a sapphire cos and it seems the KPI is 15 degrees odd so you would think that my Left at 14 degrees odd is closer to the truth than 7 degrees 52mins!
Need 3 door info!
Thanks for your help.
Tim.
Old Feb 15, 2014 | 06:40 PM
boy-racer-1's Avatar
boy-racer-1
have you checked your tca's are both cosworth ones? the standard base model mk1 tca is slightly shorter but fits all the same with the cosworth hubs etc
Old Feb 16, 2014 | 05:29 AM
2Litre's Avatar
2Litre
The Camber is fine TCAS equal lengths . cheers
Tim.
Old Feb 18, 2014 | 11:29 AM
2Litre's Avatar
2Litre
No one got a 4 wheel alignment print-out for their 3 door?
Cheers. Tim.
Rod-Tarry
75
Oct 13, 2015 04:44 PM
Chas
Oct 5, 2015 07:13 PM
muz
Sep 30, 2015 08:29 AM
37
Sep 17, 2015 05:05 PM
