power steering issues please help
Old Feb 8, 2014 | 09:04 PM
Thomas p's Avatar
Thomas p
Question power steering issues please help
ok here goes.. replaced all power steering pipes on the rack as they wer all leaking. now my steering wont respond it violently jiggers from left to right will only turn from left to right sometimes if i hold it but does it by itself it will not allow me to turn from lock to lock by myself tried bleeding the system to no avail when i empty the fluid i can turn from lock to lock but as soon as i put the fluid back in it does the same thing again. its new fluid everytime. any hints or tips would be greatl appreciated thanks.
Old Feb 8, 2014 | 09:07 PM
james kiely's Avatar
james kiely
did you turn it lock to lock 5 times to bleed it once all piped back up thomas ?
Old Feb 8, 2014 | 09:13 PM
Thomas p's Avatar
Thomas p
yep i did that ive also found that with the engine off i still cant turn my steering unless i drained the fluid
Old Feb 8, 2014 | 09:18 PM
Thomas p's Avatar
Thomas p
there is no leaks but im thinking possibly air being drawn in at the rack where the input and return pipe enter and exit? as they don't seem to be tight with the 1 10mm bolt that holds both of them in with the o rings?
Old Feb 8, 2014 | 09:21 PM
james kiely
it does sound like its airlocked
Old Feb 8, 2014 | 09:24 PM
Thomas p's Avatar
Thomas p
whats the best way to bleed the system? i was taking the pipe off at the pump that goes into the rack the rack was fine before possibly a sticky valve in the rack?
Old Feb 8, 2014 | 09:33 PM
james kiely
it should bleed itself back through the powersteering tank with the cap off .just keep turning it lock to lock mate
Old Feb 8, 2014 | 09:34 PM
Thomas p's Avatar
Thomas p
ok ill try that tomorrow thanks for your advice james
Old Feb 8, 2014 | 10:23 PM
cossiestu's Avatar
cossiestu
Sure I've heard before, that you have to bleed it with the wheels on the ground, whereas some people do it with the wheels in the air? I'm no expert, don't think I've ever had the need to bleed mine!?
Old Feb 9, 2014 | 08:13 AM
2Litre's Avatar
2Litre
Not sure it would make any difference but is it plumbed in correctly after pipe replacement ?
Tim.
Old Feb 10, 2014 | 10:03 PM
Thomas p's Avatar
Thomas p
tried doing it with the wheels on the ground it was worse trying it that way i haven't had a chance to look at it propely yet because of this damn weather! maybe ill have a bit of luck on sunday
Old Feb 10, 2014 | 10:05 PM
Thomas p's Avatar
Thomas p
Tim.
yep triple checked all pipe work and plumming going to re-check and replace O-rings and try again if all else fails think ill be needing a new pump to be honest.
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
turbotrev
14
Sep 27, 2015 10:44 AM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
