Cosworth fuel pump cradle
I removed my fuel pump cradle for a cleanup. I was thinking of getting it shot blasted and powder coated. Question i have is - should I remove the mounting plate inside the cradle that is fixed in place with three pop rivets. I thought it would be a better job if removed, and coated separately - then pop rivet back in place after. I dont want to mess the whole thing up.
Any recommendations or tips? Cheers.
Ok cheers for the info - I have separated the pop rivetted section, and all bits will be going for blasting and power coat.
Now when I am at this - I am going to fit the pump wiring upgrade kit. Tonight I tried to check the voltage at pump, just to see what it is now.
I checked it with ignition on but car not running, and only got 0.5 odd volts.
Does car need to be running to get this voltage?
I removed mine and then, 're-fitted it with three small stainless nylock nuts and bolts but placing rubber washers between the plate and cradle which helps reduce future corrosion.
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
