Exterior elements
Ok, the garage I was meant to be renting down the road may have fallen through as I can no longer get hold of the guy, seems his phones permanently on answer phone, I may have to try and clear the garage out at my mums place but how are these motors being left in the elements, not ideal I can imagine, does anyone do it, and are the all weather car covers worth the prices they have stamped on them?
at the end of the day if you look after it keep it clean it will be fine. make sure theres underseal on the car and you can't go wrong these cars are ment to be used not sat around gathering dust. You will have more problems if you leave it in the garage doing nothing than driving it
Pretty sure it's been undersealed but will get it checked once iv picked it up, my intentions were just to have it in a garage when I wasn't using it rather than out sat in all elements
will be fine as been said jst keep it clean and make sure its ndersealed well and there is no leaks from uthe rbbers likearound the sun roof and door shuts and keep an eye out for damp carpetsas any moisture kept there for a extenedtime will rot the floors
Mine only lived outside......its a good excuse to drive it lol.
I washed it weekly and drove it 5days a week (this also helped with keeping bits dry and abit of fresh air)
Make sure you're car doesnt have any dodgy seals or drainage as it could encourage a build up of water in areas
