Piston rings
Old Sep 1, 2013 | 07:40 PM
turbobill's Avatar
turbobill
Default Piston rings
Another quick question people, done a quick search but couldnt find much, took the head of my cvh of, as i got low compression on a cylinder, 1,2,3are 8 bar, cylinder 4 is 5 bar, started to smoke a little, so took head off and i poured some oil on top of the piston to test to see if the piston rings have gone,now i guess it shouldnt disappear, but how long would you give it before you say there okay? Cheers bill
Old Sep 1, 2013 | 07:52 PM
studabear's Avatar
studabear
Did you not do a wet compression test first?
Old Sep 1, 2013 | 07:55 PM
turbobill's Avatar
turbobill
Yea i done a wet compression test and it did up the conpression slightly, but doesnt that just narrow it done to either a valve not seating correctly or piston rings? Maybd balve stem oil seals??
Bill
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
