How to identify an escort rs turbo head
Identifying an escort rs turbo head with the numbers on the head or is all 1600 cvh heads the same and is it just the valves that are different? Cheers
You'll get an answer here:
http://www.rsownersclub.co.uk/rsocbb/index.php
I find PF users tend to look at threads more than reply....
You've had 43 views but no reply..... You can expect this thread will go over 100 views and still not get a reply.
The series 1 forum has users that reply to threads aswell.
all i see threads which are weeks old
As far as I know the rst head is a xr2 head. Xr3i heads have injector holes/castings on the inlet ports. The rst used mfi and used a sandwich plate between head and manifold to house the injectors.
Terry
Terry
muz
Aug 16, 2015 12:57 PM
