Exhaust bracket.
Old Aug 30, 2013 | 09:01 PM
studabear's Avatar
studabear
Default Exhaust bracket.
Did the s2 have a bracket for supporting the exhaust system mounted near the fuel pump area as standard, if so was it a bolt on affair?
Both the exhausts I've had on my turbo cab have had a bracket on them in this area, (mongoose & scorpion)
I need some extra support for the system, esp as the centre clamp keeps getting clobbered on speed bumps etc. (suspension raise is on the cards)
If it is a bolt on job has anybody got one spare?
Stu.
Old Aug 30, 2013 | 09:39 PM
chunky3's Avatar
chunky3
it bolts on and usually comes with a new stainless system it did with my scorpion system
nigel b's Avatar
nigel b
bolts on the bottom of the rear hanger
Old Aug 30, 2013 | 10:19 PM
rsmark86's Avatar
rsmark86
weld an extra support in, easy
Old Aug 30, 2013 | 10:33 PM
studabear's Avatar
studabear
Thats the other option, ideally I would like something bolt on.
Old Aug 30, 2013 | 10:35 PM
rsmark86's Avatar
rsmark86
you can weld a bracket to the floor which is easy, but being a stainless system to make it easy you could buy a universal hanger/clamp to put on the exhaust and fit to the one you just welded in
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
