Converted to efi
Old Aug 28, 2013 | 08:35 PM
cooksters's Avatar
cooksters
Default Converted to efi
Hi all got escort Rs turbo dropped a fiesta efi lump in came as complete engine with loom and ecu as such. what wiring can I get rid of the exiting loom and do both computers go also can I convert my exiting throttle pedal connection.done away with the abs so i take it ill just join the brake pedals up and I'm hoping that's it any help would be appreciated thanks
Old Aug 28, 2013 | 10:07 PM
rsmark86's Avatar
rsmark86
give dubs44 a ring mate he knows what to remove and can do it very quick
clutch pedal you need either a efi mk4 pedal (xr3i or efi orion) or mod your one?
when getting rid of the abs i dont know what you mean join the pedals together?
you bridge out the abs wire to complete the curcuit to complete the system?
Old Aug 29, 2013 | 05:43 AM
cooksters's Avatar
cooksters
Yea have tried to ring dubs44 but no joy have sent him another msg to ring me as for the brakes they all joined the abs unit so I would have to put a join in as have taken out the abs. Was that clutch or throttle cable clutch shouldn't be a problem as have used my old gearbox thanks for reply
Old Aug 29, 2013 | 06:08 AM
rsmark86's Avatar
rsmark86
oh yeh lol its throttle pedal that you need efi pedal not clutch lol
Old Aug 31, 2013 | 11:44 AM
cooksters's Avatar
cooksters
Also have got rid of the abs has anyone else done this is it a case of getting some connections and joining the brake lines couple of other things as well air box which one will I need and fuel wise does anyone no what I gotta do with that i take it modding it some sort of way thanks
mondeomark
Sep 28, 2015 06:28 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
Neil Clark
Sep 8, 2015 07:06 PM
hopper350
Sep 4, 2015 12:53 AM
