mtx box
Old Aug 23, 2013 | 11:21 PM
mgtkr1's Avatar
mgtkr1
Default mtx box
im thinking about biting the bullet before this gearbox dries enough. does anyone do a fitting kit for the mtx box ie mount/driveshafts. which box should I be looking for, a focus rs one appropriate? any info will be appreciated
Old Aug 24, 2013 | 05:43 AM
rsmark86's Avatar
rsmark86
crazycage on here for mounts and shafts, as for boxes you have a few choices.
early manual linkage type box (rs2000/ mondeo) these are very cheap but come without a lsd so if thats something you want then thats extra
the mk1 frs box comes with quaife atb as standard and is a brilliant box, it has cable shift and from what "i've heard" its alot easier to do than the manual linkage
BUT its a hydro box type so you will need to do extra work to get this set up working in your car (karlos g has a good guide on this) and its got a electric speedo so you would need all the relevent bits to get this to work.
one that i think would work well for a basic DIY'ER that is having a go themselves would be to find a mtx with cable shift or manual linkage thats manual speedo not electric and possibly cable clutch and fit the frs internals in that casing
or just get that box and fit a lsd too it, it might cost more for the box but you will save alot in not having to buy all the componants to sort the speedo and hydro clutch ect
that would mean not having to figure out how to sort the hydro set up, and electronic speedo set up, clocks ect, and wouldnt cost a great deal to get them swapped as someone like karlos g would most likely do it cheap.... i know i could not do these things so this is the route i would use
There maybe other ways to do the conversion but you need to look at all ways and see what suits your needs and budget first.....
Old Aug 24, 2013 | 08:08 AM
Gadget's Avatar
Gadget
Spanner monkey
I have gone for the mondeo mtx box as was advised that the Focus RS box ratio's wouldn't be too great when fitting it with my 15" wheels.
As said already, crazycage off here for mounts and shafts, Focus RS clutch fits in with no mods, and the hydro clutch is a pretty simple mod with plenty of guides on here.
Old Aug 24, 2013 | 10:35 PM
rsmark86's Avatar
rsmark86
i need to look into it all for my fiesta at some point, im using a diesel ib5 with s2 lsd to get it up and running
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
