1.4tdci fiesta/fusion clutch change
Wife's fusion is up for a clutch (occasionally makes a noise like a quiet honking as well as slipping if its given a boot full
I have some questions if I may
Do they have a dmf? (Dual mass fly)
If so should I fit a solid one while I'm reclutching?
Is there a 6 speed gearbox that will happily clamp to the 1.4 engine, it would be excellent if I could keep the revs down on a run as I'm getting into this efficiency lark as its giving 63mpg but not in a 70 mph long run where the engine is having to rev alot, well I don't thin it does ill work out the weekends trip later
Anything else you think I should know before jumping in
Many thanks
Many thanks
