Zetec Turbo Flywheel & CPS ?
Old Aug 20, 2013 | 06:58 PM
rs milesy's Avatar
rs milesy
Default Zetec Turbo Flywheel & CPS ?
I have a silvertop 2ltr zetec turbo engine fitted with the 18 zetec flywheel, but the flywheel seems to be damaging the CPS, I bought the engine already built from a Red S2 broken on here a while ago, any ideas on which Crank position sensor I should be using as the one fitted looks like it is too long ?
Thanks
Old Aug 20, 2013 | 11:05 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Try putting a washer under the sensor between it and the bit it bolts too. That should space it away from the back of flywheel a little. if it doesnt start, then the washer is too thick lol.
Old Aug 21, 2013 | 05:18 PM
xrmalin's Avatar
xrmalin
Drop me a text Milesy depending on which flywheel you went for in the end I should have one of each 1800 & 2000 you can have from my donor engines.
Mark.
Old Aug 21, 2013 | 10:49 PM
boeb's Avatar
boeb
Had this prob with ma zvh ..found out there is a few different length and width 1 s....sure the boy that fixes ma car fitted a fiesta rst 1 ..al speak to him to check for deffo tho...a blew that engine up so its prop still sitting on the broke engines pile lol
robnock
21
May 13, 2019 05:29 PM
mrknifey
Aug 30, 2015 11:48 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
