GAZ top adjustables9not coil overs)
Old Aug 13, 2013 | 09:17 PM
Si74's Avatar
Si74
Default GAZ top adjustables9not coil overs)
Picked up an unused rear pair of these that I want to put on when I rebuild the car (fronts to match would be nice, funds allowing.
Question - I have no idea how to adjust these and their website is as helpful as a chocolate teapot.
Also the burton catalogue shows these with fancy bump stops which didn't come supplied, will the cars standard ones fit?
Old Aug 18, 2013 | 06:58 AM
Marc D's Avatar
Marc D
Standard bump stops should fit. There should be either an adjuster knob on the back of the shock or on the top a small nut just above the thread. Screw anti clockwise to soften and clockwise to stiffen
Hope this helps
Old Aug 18, 2013 | 09:45 PM
Si74's Avatar
Si74
Thanks Marc,
they have the small nuts on the top. Not sure what they are set at but seem pretty stiff One of my front shocks is goosed so a good excuse to get a pair of Gaz for the front end too
SmudgerByName
52
Jul 28, 2016 06:14 PM
yatta
Sep 1, 2015 11:28 AM
borboyous
Aug 22, 2015 11:17 AM
155lee
Aug 14, 2015 11:21 AM
Bosch
Aug 4, 2015 05:14 PM
