Injectors
Old Aug 12, 2013 | 08:31 PM
JoshXR2's Avatar
JoshXR2
Default Injectors
Have seen these on ebay
http://www.ebay.co.uk/itm/SIEMENS-DE...item2ec9ae4322
Will these be suitable for a 2.1 zvh using an EFI inlet?
Old Aug 12, 2013 | 10:09 PM
delbee1's Avatar
delbee1
What management are you running? And how much power are you looking to achieve?
The siemens 55's and 83's are low impedance so if your looking for an alternative to those the ones in the link say they are high impedance with low impedance characteristics.
Cant you use dark greens, greys or light blues??
Old Aug 13, 2013 | 08:57 AM
JoshXR2's Avatar
JoshXR2
I'm using ofam evu
Old Aug 13, 2013 | 09:33 AM
rsmark86's Avatar
rsmark86
You need to check what impendence you need first, but they are cheap
I got a set for £75 delivered and will flow well over 300bhp
Dark greens ect are the wrong impendence for ofab so I'm guessing this is the same for ofam
Best person to speak to is rob at boost monkeys
Also it would help if we knew your spec?
Old Aug 13, 2013 | 03:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
OFAM (MS2) can run either high or low impedance injectors, those Deka IV's in your link are a good injector for the money and I use them in a lot of builds.
They will flow for about 300bhp in a CVH and around 370bhp in a Zetec turbo, so for a ZVH which has a poor BSFC like a CVH I imagine they will do somewhere nearer the CVH figure.
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
