Rear wing..
Does anyone know if you can still get these from anywhere? I've not had any luck with my local suppliers.
The part around the petrol filler has gone a bit nasty and needs chopping out an replacing.
I know, had a place just call me back wanting Ł470 for one!
well looking at the inner wing i've got and that outter wing, the bit the holds the fuel filler neck isn't part of either.
Yeah mine had a little blister of rust underneath the filler neck screw. Started prodding with a screw driver and the whole thing came away.
Decided to just make that part of the wing up myself.
I made one up when I restored my s2 just unpicked it from the outer panel and fabricated a new one up. The hardest part was making sure it was the same depth as the old 1 so it sat flush when the filler cap was on. I had the inner and outer wings off though so it made it a lot easier for me.
155lee
Sep 6, 2016 11:10 AM
The Enigma
Sep 12, 2015 10:12 PM
