Quick one, removing engine
I did a series 1 in the back yard years ago, I'd already got the head off as it cracked a piston, the block itself came out pretty easily. I put the block in on it's own and put the head on after, it's easier to do that, as you're not chasing the motor round and round to tighten the head bolts if you don't have an engine stand/someone helpful to hold it.
if its a s2 and your dropping the block out the bottom then you wanna remove the anti roll bar first, I found out the first time I dropped 1 of mine out, struggled like hell and had to unbolt the clutch through the gap inorder to get it all out.
The next time I removed it I think I removed the bottom pulley, roll bar and it came out a treat.
(3cvh's in the bay last year)
matman
Sep 9, 2015 05:45 PM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
