HELP Wilwood 4pot brake conversion on s2 rs turbo
Old Jul 24, 2013 | 01:09 AM
RSTste93's Avatar
RSTste93
Default HELP Wilwood 4pot brake conversion on s2 rs turbo
Hello everyone I'm after some braided brake lines for wilwood 4pots for my s2 Rs turbo, it is a male connector for the brake line on the brake caliper and I need a braided line that will definitely fit it, is there a off the shelf part for this or will I need custom made brake lines? I would really appreciate any help if anyone knows, thanks.
Old Jul 24, 2013 | 12:33 PM
rs milesy's Avatar
rs milesy
I am having the same problem with my willwood calipers on my Series1 RST, the thread on the bleed nipple is M10x1, the braided lines I had for the original calipers are way too short, I am thinking about getting some made with a banjo connection on the caliper, and the original connection to the metal brake pipe.
Old Jul 24, 2013 | 06:17 PM
RSTste93's Avatar
RSTste93
Where can you get braided lines made mate?? My problem is its a male nipple on the caliper and a male nipple on the end of the standard brake line "/ so I need a brake line made with a female nipple if you understand what I mean??
Old Jul 24, 2013 | 06:44 PM
nigel b's Avatar
nigel b
buy all the bits seperate and make the hoses yourself in situ
try think auto
original
Apr 28, 2026 05:20 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
matman
Sep 9, 2015 05:45 PM
Ben26
Aug 27, 2015 08:56 PM
