Temprature problems
Old Jul 18, 2013 | 09:23 PM
lewis.philcox's Avatar
lewis.philcox
Default Temprature problems
Hi Guys.
my name used to be nos burner on here.
ive got a 5 door s2 but in this summer heat I have serious temp problems.
100 degrees or even more constantly its this stupid Intercooler and rad issue AGAIN! rogeyboy will remember me and this as we share the same issue! at what temp should I start worrying? I have seen 115 so far
cheers
Old Jul 18, 2013 | 09:35 PM
rsmark86's Avatar
rsmark86
if its a rs turbo engine..... has it got a rs turbo rad or standard 5dr?
make sure your running the proper rst one and give motorsport developments a ring, for Ł35'ish i got a uprated fan switch and low temp thermostat and they were the best mods for the money i ever got for a rs turbo
dubs44 on here has a nice rad for sale too, just mint standard one
Old Jul 18, 2013 | 09:37 PM
lewis.philcox
Sorry I have a full airtec turbo rad from msd and a radtec cooler I think it is. My fans are on a switch currently but even crusing at 65 the temps are still 100 degrees
Old Jul 18, 2013 | 09:41 PM
rsmark86's Avatar
rsmark86
phone msd mate
i had the alloy rad and cooler and had the same problems, it would only kick the fan in when it started to boil
fitted their fan switch and thermostat and cured it and would only ever get to just under 3/4s with outside temps in the high 20s C
VALUE FOR MONEY THEY WERE BRILLIANT
Old Jul 18, 2013 | 09:49 PM
lewis.philcox
Cheers pal il give em a ring tomorrow
Old Jul 18, 2013 | 09:51 PM
mentalasanything's Avatar
mentalasanything
Fit a lower temp fan switch as found in the S1 (92 degree as opposed to the S2's 102 degree) and fit an MSD 82 degree thermostat. Job done. My fans kick in just past half way on the standard temp gauge.
Lee
Old Jul 18, 2013 | 09:57 PM
rsmark86's Avatar
rsmark86
good lad, the fan switch i brought because everyone you buy from a motor factor is dog sh*t, very good buy it was
Old Jul 19, 2013 | 07:01 AM
Rogeyboy's Avatar
Rogeyboy
A lower temp fan switch will not cure your problem, been there and tried it...
You need to increase airflow to your rad, at 65mph theres much more wind going into the front of the car than a pair of fans can ever reproduce, so if its not cooling then the fans wont cool it either.
Try running it with a standard ic on for a few journeys, if its fine then youve got an airflow problem. I swapped my IC and ive driled some holes in the bumper to aid airflow.
A lower temp opening stat is a good idea, ive got an 82c stat.
Old Jul 19, 2013 | 08:53 AM
lewis.philcox
I was thinking about drilling holes and side mounting the number plate either that or cutting the bumper bar down to aid air flow.. my first plan is to do a run with the bumper off for 10 mins
Old Jul 19, 2013 | 01:00 PM
rsmark86's Avatar
rsmark86
I did say he needs to 82c thermostat combined with the fan switch, another thing to think about is, are you running a rst bonnet? And rst bumper?
Both of these were designed to aid airflow (slightly) but a standard model bumper is not
Old Jul 19, 2013 | 05:31 PM
martysmartie's Avatar
martysmartie
This ^^, the fans should not be when moving anyway, op have you actually confirmed the problem is not a jammed thermostat and that the circulation is ok?
I can't see how a IC can make that big a difference to the temp, afterall the air in theory will pass through it.
Martin
Old Jul 20, 2013 | 07:57 AM
Rogeyboy's Avatar
Rogeyboy
Martin in theory yes, but i compared my radtec and my airtec side by side, and the radtec you could barely see any daylight through and the airtec there was loads... Showing the amount of restriction on the airflow the radtec caused me.
I think mark has a good point about the bonnet and bumper, i have a standard bonnet and modified bumper, im thinking of doing a few runs with an rst bonnet to see if that helps the air flow after its been through the rad
Old Jul 20, 2013 | 11:28 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Roger is correct, people get hung up on the idea that the fans play a big part in keeping temps down.... They don't, only when stationary or moving very very slowly.
OP 115 degree's is about as high as you want to safely be seeing, I've seen 120 on really hot summers days whilst boosting at 32psi for extended periods but that is to the extreme and not the norm.
Old Jul 20, 2013 | 10:59 PM
rsmark86's Avatar
rsmark86
Mk1 frs goes I over 100 degrees standard but I like too see figures lower than that
Old Jul 25, 2013 | 03:02 PM
lewis.philcox
Ive now sealed the IC and rad better however if its still no better after ford fair il be buying a new airtec cooler I think
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
