Black top zetec inlet conversion
Old Jul 16, 2013 | 07:01 PM
rsmark86's Avatar
rsmark86
Default Black top zetec inlet conversion
What throttle cable does everyone use? It's in a fiesta so already have the efi pedal? Part number would be great ?
I'm going to get all the bits to do a pedal conversion tomorrow so could get it all at once?
And has anyone got a erst .48 rear housing for sale?
Old Jul 16, 2013 | 09:51 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I use an EFI one same as when converting from MFI.
Old Jul 16, 2013 | 10:17 PM
rsmark86's Avatar
rsmark86
i see so my standard fiesta efi one will fit straight up? bargain, im liking this inlet even more as i get to ditch my bonnet vents and stop idiots saying
"yo bruv ur bonnets up"
Old Jul 18, 2013 | 07:21 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes it will, assuming your using the black top TB with the black top manifold! lol
Old Jul 18, 2013 | 07:36 PM
rhinopower's Avatar
rhinopower
Your using a black top inlet manifold and TB? The fiesta cable wont fit. You can use a mis-match of parts to make it a frs inlet tho which will work. I've got pictures if you need.
Old Jul 18, 2013 | 07:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It won't? Thats what I used...... Hmmm or maybe I used the Mondeo cable?! You've got me doubting now, either way one of them fit's with no modifications, you'll soon know by looking at the TB.
Old Jul 18, 2013 | 08:09 PM
rhinopower's Avatar
rhinopower
Blacktop tb has a peg, and the cable has a loop with a rubber/nylon insert.
Old Jul 18, 2013 | 08:30 PM
rsmark86's Avatar
rsmark86
i will have a look, so its either my throttle bodie or a mondeo blacktop zetec one
im not bothering with frs throttle bodie as nigel b ran 2bar with a gt28 through a blacktop zetec before it started to struggle
im not going to run that, more like 1.5 bar on a 4x4 cossie t3
Old Jul 18, 2013 | 08:37 PM
rhinopower's Avatar
rhinopower
I'm using a mondeo throttle body, and cable, with a frs spacer plate
Old Jul 18, 2013 | 08:45 PM
rsmark86's Avatar
rsmark86
spacer plate? is that to just raise it up?
i will just get the mondeo cable as its a mondeo inlet i got and fitted vxr injectors and frst fuel reg
Old Jul 18, 2013 | 08:50 PM
rhinopower's Avatar
rhinopower
http://www.fiestaturbo.com/forums/fi...76357/page735/
Spacer plate routes the bypassed air correctly so that the iscv will work Pictures is jsut over half way down the page on my macbook
Old Jul 18, 2013 | 08:52 PM
rsmark86's Avatar
rsmark86
im on gotech mfi pro so not needed lol
Old Jul 18, 2013 | 08:56 PM
rsmark86's Avatar
rsmark86
oh dear slightly love the project mate, proper sleeper
rhinopower's Avatar
rhinopower
I tried gotech... it lasted on the car a little under an hour before i gave up on it and switched to megasquirt! I presume your using jamsport to map it as nobody else i enquired with would touch it?
Old Jul 18, 2013 | 08:57 PM
rhinopower's Avatar
rhinopower
Cheers! I just need to find a bit more love for it, hot weather and lack of funds is getting me down
Old Jul 18, 2013 | 09:06 PM
rsmark86's Avatar
rsmark86
i got nearly everything to finish my car except a down pipe but working nights and wake up mid afternoon and go to work on it and keep side tracking into the swimming pool lol
wont be long and i will moan its to cold to work on it lol
Old Jul 28, 2013 | 06:54 PM
studabear's Avatar
studabear
I used a focus rs inlet/throttle body and a xr3i efi cable and pedal, I cut the throttle cable bracket down on the throttle body and chopped a 3i efi bracket down and made a hybrid bracket. My mate welded it up and it works a treat. Can get a picture if needed.
Old Jul 28, 2013 | 06:57 PM
rhinopower's Avatar
rhinopower
Yes please!
Old Jul 28, 2013 | 07:05 PM
studabear's Avatar
studabear
I will grab a pic in the next day or so of it without the cable fitted.
But its basically the part that would hold the cable on the cvh welded onto the frs.
Old Jul 28, 2013 | 07:25 PM
gup's Avatar
gup
Can you use the plastic inlet off the black top or silver top 1800 Zetec
For a turbo
Old Jul 28, 2013 | 07:28 PM
studabear's Avatar
studabear
plastic blacktop/frs inlet is same thing, although the throttle body is different on the frs afaik.
Old Jul 28, 2013 | 09:44 PM
rsmark86's Avatar
rsmark86
just make sure its a 1 piece inlet
ive got a full mondeo blacktop inlet that i paid £35 delivered complete, then give £75 for vxr injectors and frst fuel reg
bargain
Old Jul 29, 2013 | 01:01 AM
gup's Avatar
gup
That stood my mate bought a complete engine and it came with the inlet
So was asking about using it rather than the moody Efi inlet onto his Zetec
Old Jul 29, 2013 | 04:36 AM
rsmark86's Avatar
rsmark86
i would, i like it because i can bin the stupid bonnet spacers once its all fitted up
robnock
21
May 13, 2019 05:29 PM
Porplus12
Sep 10, 2015 07:20 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
robnock
Aug 22, 2015 10:51 AM
gingerturbo
Aug 11, 2015 09:44 PM
