Engine Still Tapping After Cam Change...
Old Jul 16, 2013 | 07:48 AM
Rogeyboy's Avatar
Rogeyboy
Default Engine Still Tapping After Cam Change...
So, i changed the Camshaft in my car after it started tapping and causing a light miss-fire.
Got it all back together last night and after running the cam in it still taps and settles to a slight mis-fire.
The Cam i removed was dead, over 2-3mm missing off some lobes.
I havn't had the rocker cover back off yet, but im thinking a dropped valve maybe?
Old Jul 16, 2013 | 07:54 AM
luke19790_3's Avatar
luke19790_3
Is it getting oil to the cam?
Old Jul 16, 2013 | 08:20 AM
Haston's Avatar
Haston
I have the same problem drove it a few miles now there is a terrible miss
Old Jul 16, 2013 | 09:27 AM
haz87's Avatar
haz87
Which cam did you go for in the end? (not that it really changes anything)
Whats your oil pressure? hot/cold
And i take it you ran it in properly?
Old Jul 16, 2013 | 10:40 AM
Rogeyboy's Avatar
Rogeyboy
Havn't tested oil pressure... I dont have a gauge!
Tried it with a new pattern cam and and good used cam from my collection. Both do the same.
It taps all the way through the 20minute run in and still taps now.
I'll pull the cam out tonight, inspect the head and check theres oil getting up there! Maybe run it without the rocker cover...
Old Jul 16, 2013 | 10:42 AM
Rogeyboy's Avatar
Rogeyboy
Another thing to note is that, ive recently changed to fuchs 10w50 oil, was using castrol 10w40 before. When i dropped the oil out after replacing the cam there was afew bits of "mayo" in it, leading me to think the head gasket has failed... But the cooling system doesnt lose pressure!
Old Jul 16, 2013 | 11:06 AM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Clogged tappet???
Old Jul 16, 2013 | 11:20 AM
haz87's Avatar
haz87
Hope you fitted new lifters with the new cam. If not you've wasted your time anyway. Using a second hand cam was a waste of time IMO (with cvhs its just pointless).
Cant believe you haven't got an oil pressure gauge tho
Old Jul 16, 2013 | 11:36 AM
Rogeyboy's Avatar
Rogeyboy
I kept the original cam and lifters from an old efi engine, all labeled up. So no issue there!
The tapping was instant as soon as the engine started... So i think its something wrong with the valvetrain, valve stuck open etc?
Old Jul 16, 2013 | 11:43 AM
haz87's Avatar
haz87
When you say labelled up do you mean tappets in order too? If so thats fair enough.
Did you check over the rockers when you had it stripped. Ive had 2 (on seperate occassions) crack underneath that looked fine in situ, but when i removed them i spotted very fine cracks which under lift were expanding and causing a racket and essentially flex in the valvetrain.
Not alot else that can tick or cause misfires other than a burnt out valve tbh (compression test will soon show that one)
Old Jul 16, 2013 | 12:59 PM
luke19790_3
Had this once on a engine, oil wasn't getting to the cam.
Check the pressure but if it was me the head would be coming off
Old Jul 16, 2013 | 01:43 PM
Rogeyboy's Avatar
Rogeyboy
Harry i'll check the rockers, got afew spare sets so thats a good shout...
How will i tell if oil is getting up there without a gauge? Run it with the cover off?
Old Jul 16, 2013 | 04:39 PM
rsmark86's Avatar
rsmark86
It generally will tap all the way through the running in phase while its bedding in and the tappets fill with oil
Have you changed the oil after running it in? I hope so as all the swalf and metal filings will be running around your engine
When ever I have fitted a cam it's taken an oil change and a 20min run to get it to settle in
Check rockers are tightened correctly aswell
Old Jul 16, 2013 | 04:41 PM
rsmark86's Avatar
rsmark86
Disconnect power to fuel and spark and turn over with cover off and plugs out
You want it to pump into the head not just trickle
Old Jul 16, 2013 | 04:46 PM
Rogeyboy's Avatar
Rogeyboy
Yeah ive tried 2 different cams, properly run in. Its tapping the same as before, n giving a slight miss at idle...
I'll try cranking with plugs out tonight
Old Jul 16, 2013 | 05:12 PM
rsmark86's Avatar
rsmark86
Is it a loud tapping, almost like a knock or just a loud ticking sound
If its a loud tapping it would make me think that a lifter isn't getting any oil? But without seeing the car it's hard to see
Old Jul 16, 2013 | 08:17 PM
Rogeyboy's Avatar
Rogeyboy
So..
Cranked it over with rocker cover off n plugs out, lifters get soaked in oil within 2-3seconds and soon after the head has loads of oil round it.
Compression Tested her to, 138, 140, 140, 142. All 140psi near as makes no difference.
Checked the bores with a scope and nothing obvious... Some droplets in cylinder 1 around the head gasket, but not alot, could be excess fuel?
Maybe mis-fire could be a faulty coilpack and the tapping could be a lazy lifter or cracked rocker? Basically 2 seperate faults?
Old Jul 16, 2013 | 09:44 PM
rsmark86's Avatar
rsmark86
that misfire could be whats causing the excess fuel in one cyclinder?
i would take it for a slow run down a long carriage way and see if the tapping clears, my guess is the tapping will be on the same cyclinder as the misfire
Old Jul 16, 2013 | 11:05 PM
B19 JUB's Avatar
B19 JUB
tapping sounds like a lifter knackered tbh.surprised u haven't got an oil pressure gauge dude.my orion runs 80psi+ when cold and will stay around 60psi when at cruise
Old Jul 17, 2013 | 07:35 AM
Rogeyboy's Avatar
Rogeyboy
I'll put it back together today and run it up...
Old Jul 17, 2013 | 04:24 PM
Rogeyboy's Avatar
Rogeyboy
Got it all back together this morning and its fine now, good as gold...
When i removed a plug todo comp test last night it wasnt very tight, im wondering if that caused the tapping in the same way a blown exhaust manifold gasket does. Looking at it this morning it didnt have a compression washer on it. Would also answer to the misfire...
Plugs went in before the cam change was even thought of, and i didnt do much mileage on them before a tapping developed, plug working loose?
The mis-fire was still apparent on start up, but cleared with a quick blip of the throttle, lifter pumping up to take up the play in the worn cam?
So new cam solves the mis-fire...
But new plugs cause another one along with a tapping noise.
Old Jul 17, 2013 | 04:33 PM
haz87's Avatar
haz87
Hmm just keep an eye on it. If its sorted happy days, but we all know these engines like to fix themselves then break again several times per week
Old Jul 17, 2013 | 05:22 PM
rsmark86's Avatar
rsmark86
My advise is if it has fresh oil after the cam was run in, take it for a steady drive down a couple of junctions of motorways, it will help bed it in better and stop the tap on start up
Do this before giving it beans, it has always worked for me
Old Jul 17, 2013 | 08:36 PM
Rogeyboy's Avatar
Rogeyboy
Ive taken it for a nice long drive tonight... Cambelt tensioner has started rattling, its never fucking ends does it!?
Old Jul 17, 2013 | 08:57 PM
rsmark86's Avatar
rsmark86
time for a cambelt change, to be honest i change them and the tensioner everytime it comes off, might aswell put a water pump in at the same time and save the risk of having to do it twice
Old Jul 17, 2013 | 09:21 PM
slammedorion's Avatar
slammedorion
Now you've gone Efi, be easier to go zetec turbo lol...
At least it's a easy fix...
Old Jul 17, 2013 | 09:44 PM
rsmark86's Avatar
rsmark86
straight swap with some adaptor plates, bottom coolant hose, and drill the flywheel bolt holes slightly
Old Jul 18, 2013 | 07:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
A lose or ill fitting plug does indeed sound like the culprit, it would cause both problems, certainly with the compression washer missing! lol
At least a tensioner and belt are cheap and easy!
Old Jul 18, 2013 | 10:08 PM
studabear's Avatar
studabear
roger if you need a tensioner and water pump I have both that have done less than 1000 miles, cover the post and I will send them to you.
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
