Australian owned Series 2 idles but wont drive! HELP :'0(
Old Jul 16, 2013 | 07:47 AM
borboyous's Avatar
borboyous
B83 YKM
Default Australian owned Series 2 idles but wont drive! HELP :'0(
Hey - thanks for looking,
I have a 1986 S2 that I bought here in Australia, its had an EFi conversion, runs on adaptronic management and I had it set up at EFi performance dyno about 2 weeks ago. Before it went for its dyno tune it had a problem that I could only describe as a 'misfire' - when you tried to drive it it would just stall - it also sounds like its backfiring through the inlet side of things ( I could be mistaken but thats what it sounds like ). I got it back from the dyno and it drove brilliantly, pulled really well through the gears and the 'misfiring' was gone. Now here we are a little over a week after it was tuned and its worse than ever! It will start and sit and tick over without too much drama, but if you try and rev the engine or drive it, it just pops and bangs and conks out! Now I dont know too much about these cars other than I love them and I believe mine is one of only 2 S2s out here in Oz, needless to say there isnt a whole heap of knowledge about them anywhere here - can anybody point me in the right direction in getting it running? I have some limited spares (dizzy cap, rotor arms etc.). Any help or suggestions would be really gratefully received.
Craig.
Old Jul 16, 2013 | 12:24 PM
millybuzzin's Avatar
millybuzzin
Have you tryed the timing belt.you only have to be a tooth out and it can misfire
Old Jul 16, 2013 | 06:24 PM
studabear's Avatar
studabear
Map sensor connected up properly?
Old Jul 16, 2013 | 06:53 PM
Hobomassiv's Avatar
Hobomassiv
I had a similar issue with my Ka RST. It would rev ok-ish until boost started building and then hold back and 'miss' and cut out. I have a feeling my timing may have jumped a tooth, but this i realise after having taken it to peices and had a full rebuild etc etc
Old Jul 17, 2013 | 08:51 AM
borboyous's Avatar
borboyous
B83 YKM
Hey guys, thanks for the replies. So today Ive whipped the plugs out and they all look good, checked that the cambelt hasnt jumped a tooth and that seems fine, checked voltage at the fuel pump and thats where it should be, made sure everything is connected and checked as many earths as I could find. Ive checked all hoses are fastened tight etc. The car now starts, runs and drives until it hits boost then the power drops away abruptly and in a very scary fashion! So I've parked it up as I'm out of ideas, has anyone ever seen this happen to their car? Thanks Craig
Old Jul 17, 2013 | 09:59 AM
XR2's Avatar
XR2
two conversions done to the car. So all we can do is guess.
Is it possible to connect a laptop to you ECU to check live values (sensors, iginition table, fuel amount, afr etc.)?
Old Jul 17, 2013 | 10:47 AM
Danwood79's Avatar
Danwood79
Have you checked the dissy cap as mine did this as it had a hairline crack in it.
Dan
Old Jul 18, 2013 | 04:44 AM
borboyous's Avatar
borboyous
B83 YKM
I have the software etc to get live values etc but would have no idea how to interpret them :0/
Old Jul 18, 2013 | 05:37 AM
rsmark86's Avatar
rsmark86
ive seen 3 cvh turbo engines in the last year that the timing belt was a tooth or two out causing the same problem
ive seen them with all the valves bent and made a simular problem but it would not idle if that was the cause so at least i can say in my experience it doesnt sound internal, but electrical
you say you converted to efi but then mention a dizzy cap? wouldnt it be fitted with a coilpack? does sound like a coilpack/ incorrect firing order or something along those lines.
ive also experienced a alternator electrical drain that would cause a misfire on boost but you say its as soon as you rev it?
Old Jul 18, 2013 | 05:39 AM
rsmark86's Avatar
rsmark86
if you could get the data log/ live values and post up help with adaptronics im pretty sure that someone on here like stu/chip/mark ect will be able to help
Old Jul 20, 2013 | 11:33 PM
borboyous's Avatar
borboyous
B83 YKM
Thumbs up
Thanks for all the suggestions, Ive ordered a serial lead to plug into the ecu and will be back when it arrives
Old Jul 21, 2013 | 12:33 AM
spmotorsport's Avatar
spmotorsport
hello sir, where abouts in brisbane are you as there are a few ford rs owners here and on the gold coast that meet up on a regular case and all work on cossie's, i'll be the first to say i'm not that familar with the s2 escort but we have a few poms that have owned them so may be able to help but with two conversions done on car it may be a little difficult, would be great to see it among it's rs pairs at shows as well
Old Jul 24, 2013 | 09:12 AM
borboyous's Avatar
borboyous
B83 YKM
Hi there!
Im in Redcliffe on the northside of Brisbane - are you in the RSOC over here? Im a member of that too! Thanks for the offer of help too - much appreciated!
OK, I have my serial lead and can link my pc up to the ecu and as exciting as that is I'm wondering what I would need to post on here to help understand whats going on with my car :0/ Any suggestions as to what needs to be seen will be gratefully received!
Thanks
Craig.
Old Jul 27, 2013 | 10:01 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
We need pics of Aussie rs turbos
Old Jul 27, 2013 | 11:44 PM
lockie's Avatar
lockie
is it running much boost & hitting limiter???? (check actuator/turbo pipes)
or map sensor fooked/pipe
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
gingeRS
Sep 4, 2015 06:29 PM
