Cam Wear
So, after some loss of power issues and a slight mis-fire on start up, my car has started tapping... So the usual culprit (the cam) was taken out last night and there are various wears marks and pits in it... Ive also measured the cam up, to highlight the wear for you guys
Lobe 1 36.5mm
2 36.4mm
3 36.5mm
4 36.1mm
5 35.1mm
6 35.8mm
7 36.5mm
8 33.9mm and worn very unevenly, with the surface of the lobe looking corroded and pitted!
The lifter on number 8 was dished underneath but cam out easily and the lifter on 6 was collapsed, held no spring back pressure...
Im now making the decision of a standard pattern cam for around £100 with lifters or a Kent/Newman for £300+!
I also noted that the sides of the lobes are all showing signs of wear and are very rough in casting, i think when i get a new cam i will spend some time de-burring and cleaning the lobes up with a fine file and some wet and dry before installation. Has anybody bothered with this before?
Also i was thinking of having the cam hardened, or would it then eat the lifters?
Lobe 1 36.5mm
2 36.4mm
3 36.5mm
4 36.1mm
5 35.1mm
6 35.8mm
7 36.5mm
Bad news.
All of the metal bits from the worn down camshaft and lifter will be in the sump, oil pump and oil passages.
You will be taking a chance just replacing the cam and lifters. I would remove the sump pan and clean out all iron shavings, I would also take off oil pump and open it up to inspect for debris and damage. While down there inspect bearings.
No you can't Karlos...
I can an E39 M5 tho lol!
Im going to oil and filter change the car and fit a magnetic drain plug... Done it this way before and the engine was fine! Ive just ruined £50 worth of oil tho!
Mc5506
Oct 5, 2015 09:57 PM
