wasted spark
Old Jan 8, 2013 | 06:26 AM
lmans's Avatar
lmans
Default wasted spark
i have a 350+bhp saff, just wondering is there any down side to doing a wasted spark conversion,roughly how much it cost to get it done please?
Old Jan 8, 2013 | 07:05 AM
fezzajsy's Avatar
fezzajsy
speak to msd mate..
Old Jan 8, 2013 | 08:24 AM
James @ M Developments.'s Avatar
If you cann do it DIY its Ł400 for the kit, otherwise drive it up and drive home with it fitted for Ł500,
Well worth while doing it to any cosworth imo.
Old Jan 8, 2013 | 09:02 AM
KSA-Cossie's Avatar
KSA-Cossie
Wouldn't have a Cossie without it tbh
Old Jan 8, 2013 | 12:06 PM
Rsmat's Avatar
Rsmat
Same here... My car idles and drives miles better with it IMO
Old Jan 8, 2013 | 12:43 PM
Karl 3dr's Avatar
Karl 3dr
Does the wasted spark with a level 6 ecu or does it have to be a level 8?
Old Jan 8, 2013 | 12:45 PM
Will work with any Cosworth weber ECU
Old Jan 8, 2013 | 01:05 PM
DaveCrack's Avatar
DaveCrack
It's worth every penny! Car runs so much smoother and more stable! On idle, in town or on WOT faultless!
Old Jan 8, 2013 | 01:09 PM
Karl 3dr's Avatar
Karl 3dr
Cheers James, good to know I can swap it over to my new car then.
Old Jan 8, 2013 | 03:33 PM
lmans's Avatar
lmans
Thumbs up
nice one lads, looks like thats the next mod then
Old Jan 8, 2013 | 07:37 PM
MalZon's Avatar
MalZon
Needs remapp after conversion? Or just mod är drive away as usual?
Regards/Jonas
Old Jan 8, 2013 | 07:48 PM
Karl 3dr's Avatar
Karl 3dr
No remapping needed mate, just fit and forget
Old Jan 8, 2013 | 07:52 PM
st220kyle's Avatar
st220kyle
what are the advantages of this conversion? i dont really understand how it works/is an improvement?
Old Jan 8, 2013 | 08:11 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Well worth fitting. My car runs so much smoother.
It's basically a modern car style ignition system, gives a stronger spark and fires on 2 spark plugs at a time instead of 1-3-2-4 or what ever cossie's order of spark is, Gets rid of the need for a distributor.
Just fit as per instructions with the 2 pins through the grommet and making sure this (picture) is removed and the 2 wires going into it are put together.
Old Jan 8, 2013 | 08:33 PM
BRAMMER's Avatar
BRAMMER
I fitted mine 5 years ago and never had an issue with that side of the car at all, never had to replace sensors, leads or coil pack
Old Jan 8, 2013 | 08:44 PM
martysmartie's Avatar
martysmartie
The two main benefits are a stronger spark is delivered and you don't get voltage loss like you would with a dizzy, as the powered is delivered straight to where it's needed, i.e. the plugs.
You then don't get the chronic misfiring, nor need to run tiny plug gaps, which otherwise would be needed on higher power Cosworth's.
The dizzy IS still required for the phase sensor and also it can't simply be removed as it's part of the oil pump drive, so this needs machining work etc it can be removed and the sensor needs moving to the cam cover.
Martin
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
DixieTheKid
Sep 14, 2015 09:04 PM
