Front castor issue , 3dr cos
Hi all,
Have built up the front of project trackshed with a mismatch of bits and have ended up with more castor than my front bumper can handle , bumper won't fit on.
What have I done ???? Anti roll bar bushes backwards ???? Wrong anti roll bar ????
1st guy will prob spot the issue when I post a few pics ....
That will be addressed in the new year as i'm having 9" wide wheels on the front so i'm going to do that mod where you space the arch out.
Wish they still made that bracket brand new though looks like i'll have to get a new one fabed up.
That is the only rusty bit on the car thou
Rich
Rich
Rich
Rich
Rich
Rich
special k is good at making them mate
That's a 4x4 roll bar mate, ya need the saff or 3dr roll bar ,personally I'd go with a saff 1 , and double check you've got 2wd lower arms as well ,
If you wire brush the top or bottom of the roll bar near the end ( I think it's on the drivers side ) you'll find a number stamped into the bar starting with a "h"
But I'm 100% sure it's a 4x4 bar
3dr roll bar was a h13 and a saff roll bar was h14
Hi all,
Hello mate, I put a 2wd setup in my old escos with the original 4x4 ARB and it did this! i couldn't get the bumper on! When i changed it to a 2wd one it was spot on.
Was it a mission to get the antiroll bar ends in the lower arms as mine where a right bastard when i had the 4x4 ARB?
Ronnie,
Cheers lad, price it up so and let me know what you need, tape up the threads well or bang a few nuts on as paddy van driver will swing em into every stone wall in Ireland...
I had to put a strap on mine originally to pull it all togeather but when i put the 2wd ARB in it was a piece of cake!
I would say thats ya prob.
Rich send me your number mate and I will take some pics of it all and txt them over
undo the bolts a little bit and then drop it on the deck to let everything settle and bounce properly before tightening them up again
but i'd say you've got the wrong arb too as it's pointing a bit funny
