cosworth vibration!
Hello to all,
I would like to ask about my cosworth vibration,so i have replace all stock bushs with polyurethane,the vibration comes from the rear,i have check my wheels 3-4 times and balanced too,my prop shaft have new joints and balanced too,(i have tested my second too),and the car still have the vibration,all mounts,engine,geaρbox,diff are genuine,so my exhaust is magnex and is heavy enough than single mongoose etc..,and i'm thinking due the weight, affect,and give vibration,cause the exhaust mounts are on rear beam and my rear beam have hard-polyurethane bushs,so does anyone have the same problem? also i'm thinking to add exhaust flexi,so what is your opinion?
Thanks a lot
Thanks a lot
I had a vibration problem on a classic VW once, could not find the reason for it - nearly pulled my hair out. Eventually just happened to note a slight bump on side wall of one tyre on back. Tyre was nearly new. Turned out the wire inside the tyre had split on one side - must have been a manufacturing defect. Put new tyre on and no vibration.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Adam Graham
Sep 6, 2015 06:04 AM
