Where can I get some 55lb black injectors
Old Dec 13, 2012 | 02:25 PM
arse end happy's Avatar
arse end happy
Default Where can I get some 55lb black injectors
Just went to get a chip for my car cos I've gone for a t38 turbo my 403s r not mapable with the t38 so need to find some black ones any idears where I can get myself a set cheers
Old Dec 13, 2012 | 02:33 PM
botters's Avatar
botters
competant bodger
i may be wrong but im sure i heard they were no longer available?
Old Dec 13, 2012 | 02:39 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
who told you that
the flow rate of the 55lbs siemens and the 403 bosh grey are almost identical
and we can map for either
if you have the right spec and make of t38 and the right engine spec it is easily possible to max out both the siemens 55's and bosh 403
for these instances we recommend the siemes 83lbs which I have in stock
Old Dec 13, 2012 | 02:44 PM
J1mbo's Avatar
J1mbo
B1mbo
As above, greys suit the t38 perfectly both 450bhp capable.
The siemens are slightly smaller at 435max
I'd stay with the greys
Old Dec 13, 2012 | 02:46 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Who told you that ?
I have heard some crap in my time but FFS, i do hope it was a "mate" and not a Tuner.
Steve
Old Dec 13, 2012 | 02:50 PM
arse end happy
Motorsport developments said I must have 55lb injectors for a t38 turbo chip on there online chip fing spoke to the guy on the fone cos I dident see a chip for l6 ecu with 403 an t38 turbo
Old Dec 13, 2012 | 02:55 PM
arse end happy
Originally Posted by Turbosystems
who told you that
Where r u based I'm gona get u to map my car it's a 200 block and head 403 grays cr turbo t38 50mm front mount 044 fuel pump l6 ecu or I got an l8 just trying to get a pfo9 fing
Old Dec 13, 2012 | 03:16 PM
Stu @ M Developments's Avatar
PassionFords Creator
I have just had a chat with Steve and if it was you who called about an hour ago mate you were asked to fill in the online datasheet so we had accurate details?
If that is you, you spoke to Steve in accounts and what he actually said was he was going to ask James and then E-mail you the answer but to be aware you may need to change to bigger injectors.
He has since E-mailed you asking to know precisely "which" T38 it is as they are all borderline on 403s, but some aren't suitable at all, like the TT version.
Regardless of which T38 though I am afraid i woudl disagree with most on here and strongly advise the use of Siemens 83s.
Old Dec 13, 2012 | 03:40 PM
arse end happy
Hi stu I'm dumb to all of this I just wana know wot I need to put on my car cr turbos rebuilt my t34 an made it a t38 roller baring that's all I know mate
Old Dec 13, 2012 | 04:16 PM
Paul500+'s Avatar
Paul500+
if you want some siemens 55s ive got some for sale done less than 200 miles so as new
Old Dec 13, 2012 | 04:26 PM
arse end happy
Ill see wot stu is saying I need first gona go with wot he tells me I need maby 83lb injectors now how much they gona cost
Old Dec 13, 2012 | 04:31 PM
Turbosystems
Super Moderator
I am based in Staffordshire ST57RH
I have ltd stocks left of the siemens injectors they are all brand new @Ł295 a set of 4 and a range of maps to suit l6 or l8 and for the cr t38
I can be contacted on 07587188434 at any sociable hour
Old Dec 13, 2012 | 04:37 PM
Paul500+'s Avatar
Paul500+
put a set of 83s aside for me please will be in touch in the next few days
Old Dec 13, 2012 | 05:01 PM
Turbosystems
Super Moderator
will do, if you hurry I'll even gift wrap them for Christmas with your wife's name on the card
Old Dec 13, 2012 | 05:06 PM
arse end happy
Look I'm lost all I want is a chip and a set up for my car it was a 205 block an head now a 200 block an head 4wd inlet with 403 cr turbos t38 50mm intercooler and a 044 fuel pump my chip was for greens an t34 std fuel pump 40mm front mount so pls tell me wot I need to do
Old Dec 13, 2012 | 05:39 PM
jamie956's Avatar
jamie956
What you need to do is just pick one trusted tuner and talk to them in person, if you ask 50 people what they think you will get 50 diffrent awnsers. MSD, Turbosystems & SCS are all top experanced guys but will all have there own ways of doing things.
Theres more to concidder than just maxing out your t38 i.e how good is your running gear, what clutch have you got, how long has the head gasket been in the car etc.
Running max bhp of that turbo might not be the best thing unless you are propaired to break all of the above,
Not sure of your situation and if your looking for someone to do the work for you i would concider how far away they are from you, it may require a couple of trips to get every thing sorted, so not ideal to be trecking from one end of the country to the other.
Old Dec 13, 2012 | 05:45 PM
Turbosystems
Super Moderator
feel free to call me for some free advice 07587 188 434 any sociable hour
Old Dec 13, 2012 | 05:47 PM
costina's Avatar
costina
Live long and prosper!!
Great reply
Old Dec 13, 2012 | 05:55 PM
arse end happy
I can do the work myself not looking for max bhp just a good set up so I don't run lean or blow the shit out of it
Old Dec 13, 2012 | 06:05 PM
costina's Avatar
costina
Invest in a wideband afr gauge
Old Dec 13, 2012 | 06:13 PM
Rsmat's Avatar
Rsmat
Either ring MsD or Turbo systems they will both put you right..!
Old Dec 13, 2012 | 06:29 PM
Paul500+'s Avatar
Paul500+
my advice is have a good think what spec you want pick a tuner get all the parts and fit them your self then have the car live mapped, off the shelf chips are ok but you carnt map a car properly over the phone or on a web site
a live map is the way to go m8 if you want 100% out of your spec
Old Feb 8, 2013 | 12:09 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Arent these the Siemans 55lb blacks?
http://www.fiveomotorsport.com/3102-fi11402
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Chas
Oct 5, 2015 07:13 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
timsrs
22
Sep 24, 2015 08:14 PM
