Diff play
Old Sep 23, 2012 | 11:23 AM
B16's Avatar
B16
Default Diff play
Anyone know how you measure diff play, also how much play should there be. I have about an 1" & 1/8 play in mine. If this is too much do you know anywhere in the Hants/Berks area to get it looked at.
Paul
Old Sep 25, 2012 | 10:29 PM
B16's Avatar
B16
Come on guys, someone must have some Diff knowledge.
Old Sep 26, 2012 | 08:25 AM
DAN-Saff's Avatar
DAN-Saff
There are various ways.
Take back cover off dti on the crownwheel tooth lock up the pinion and rock the crownwheel back and forwards.
You can also lock up the driveshaft flanges then mark 1 position of the pinion then rotate the pinion then re-mark and measure the difference between the lines
You should check the cv joints because 1" sounds massive IMO
Old Sep 27, 2012 | 07:18 PM
B16's Avatar
B16
Thanks Dan, will try that at the weekend.
Paul
Old Sep 27, 2012 | 07:32 PM
paddy heffernan's Avatar
paddy heffernan
heffo
Default diff
was actually wondering this myself .mine is the same on my 3 door.it feels a little jerky if in town traffic in first gear when you accelerate or decelerate.
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
ST-170
Sep 4, 2015 11:02 AM
