BMW e39 sat nav issue
Hi all just after some help, my girlfriends dad has a 530i, in the last few months the sat nav has stopped working and now so has the tv, the sat nav constantly says insert disc and the tv is fuzzy like the aerials disconnected
Also the reversing sensors don't work, I was just wondering if anyone else has experienced this and if there are any cures
I was thinking to maybe disconnect the battery for a while and see if it changes
Help is much appreciated thanks
punch it
failing that try to get a good scanner, idealy Bosch and it will tell you exactly where to follow wiring from.
similar problems were traced to roof ariel connection curroding
As Tiff says TV probably wont work as its analogue. I can still remember the day I suddenly realised I couldn't watch loose women at lunchtime in my car anymore
I also had a similar issue with my Satnav, turned out to be the laser in the DVD drive needed replacing. A relatively similar job, I did mine byfollowing a video on youtube on how to do it. Laser bought of Ebay I think for about £70.00
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
