Cosworth management non start
Hi Guys,
Just fitted a weber conversion to a car at home, went to fire it today and it started first time, left it running for a bit while i checked it over for leaks etc then went in for lunch.
Came out after, turned the key and it just cranks, wont fire. It seems i've lost the spark!
I'm getting no spark out of the king lead, still got the ignition live to the coil and the fuel pump runs when cranking so i assume that the crank sensor / signal is ok?
I haven't really done any checks as yet as i got the arse with it and just carried on fitting it all back up.
Any thing obvious to have a look at before i try parts ( don't have spares of anything anymore! )
I'm thinking that perhaps the ignition amp has shit the bed?
Thanks for any input, Gary
Check the obviousley stupid basics first, like connections and fuses
then
measure resistance of king lead,
also king lead will only fire once, to discharge the coil, then it will charge again this can be confusing mate, use one of the plug leads instead
try it again once cold incase sensor breaking down when warm/hot
has it been mapped for new application?
maby fueling is miles out.
feel free to PM me matey, or gimme a ring.
Sean.
then
Sean.
I would look very carefully at crank and phase sensor both gaps and timing, as it could have moved a little, fuel pump running just means its picked up a signal that the engine is moving.
I had months of mine not running, no spark or injector pulse, the phase sensor was not seeing enough of the trigger, eventually a kind person hooked a monitor up and then we bent the phase sensor bracket and it fired up
Aug 14, 2015 07:29 AM
