cosworth backfire
Old Sep 14, 2012 | 04:58 PM
lmosleycosworth chevette's Avatar
old school is good
Default cosworth backfire
Just built new engine and been mapping it. All is well untill about 6000rpm. It has a backfire for a few revs then clears up on load and in neutral. Number one plug is always coaked up black. We've checked /swapped injectors. Plugs, coil, leads,the map looks spot on. Any ideas please I'm lost now.
Old Sep 14, 2012 | 05:08 PM
COLEYST200's Avatar
COLEYST200
When dose it do it when you floor it or when you drive it up the revs slow . I ask this as my 3dr had this for a long time it would drive spot on all the way up the revs but when i booted it it would back fire hi up in the revs . It turnd out to be the leads were bracking down and they were to close togever when i moved them apart it sorted it i did put a new set on when i found this out . im all so running wasted spark
Old Sep 14, 2012 | 05:14 PM
old school is good
I'm also on wasted spark mate. I've swapped the leads around and it stays on cylinder one. Cheers
Old Sep 14, 2012 | 05:15 PM
old school is good
It does it on full or part throttle load or no load
Old Sep 14, 2012 | 05:16 PM
COLEYST200's Avatar
COLEYST200
Its the coil pack mate
im bilding a focus cosworth and we started it up for the first time about 4 weeks back and number 4 was not running right it was sparking but not firing the plug when it was in the head so i put the coil pack on the wifes KA and that run the same . i put a brand new one on and it ran spot on
Old Sep 14, 2012 | 05:17 PM
old school is good
No I've swapped it.
Old Sep 15, 2012 | 08:14 AM
COLEYST200's Avatar
COLEYST200
Try a new front pully . Iv all so had a lot of problems with after market pullys making the car back fire on start up
Old Sep 15, 2012 | 08:22 AM
fraser9764's Avatar
fraser9764
What management are you running? Surely you can see the output from the crank position sensor to check that? Have you done a compression/ leak down test?
Old Sep 15, 2012 | 08:42 AM
old school is good
I'm running dta p8pro all 4 cylinders identical. If it was the pulley wouldn't it do it all the time not just at specific revs.
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
