Modifry Redline Shift Bleeper
Old Aug 26, 2012 | 05:43 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Default Modifry Redline Shift Bleeper
Anyone used a Modifry Redline Shift Bleeper. It arrived from the States last Friday. Its an audible addition to my Stack Shift lights which according to Mark i totally ignore.
I have to calm down & not exceed 8500rpm is it easier for an ageing brain to process an audible alert. Mark dont like limiters so its up to me to get to grips with the way my engine revs.
Old Aug 26, 2012 | 07:45 PM
stevieturbo's Avatar
stevieturbo
C**t
Maybe an automatic might be better ? lol
Or a sequential with upshifts controlled by the ecu if driver forgets ?
I cant even find that thing on google ?
Couldnt a simple beeper be wired to an ecu output to come on in conjunction with shift light ?
TBH though, under pressure a well placed LED/light will be more noticeable than an audible sound.
Old Aug 26, 2012 | 07:53 PM
Alg1k's Avatar
Alg1k
Surely Mark could map a mechanical arm that gives you a slap at 8550,
Old Aug 26, 2012 | 08:07 PM
stevieturbo
C**t
Or just hook up an ignition coil to an ecu output with an HT lead directed to a body part.
After a few shocks, you'll soon remember when to change gear !
Old Aug 27, 2012 | 02:05 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
He certainly gave me a Verbal slap . He checked 17minutes of datalog after a rather fast run around the Newbury bypass. My PB was 8960rpm but over 8900 seven times .
Heres the bit.
http://modifry.com/products/rlb/index.htm
Old Aug 27, 2012 | 05:53 PM
JamesH's Avatar
JamesH
Heres the bit.
I can so see that happening
Old Aug 27, 2012 | 08:16 PM
zippyobrien's Avatar
zippyobrien
Is there any way of getting the boost controller to open at 8500 to drop all the boost away.
Only open thinking. I assume it all happens to fast for this to be affective.
Auto gauge ( the shit rip off of automated used to do a audible shift light. )
Maybe worth a look.
Old Aug 27, 2012 | 08:28 PM
Mark Shead's Avatar
Mark Shead
Maybe worth a look.
I will be doing something like that when its back together.
Mark
Old Aug 28, 2012 | 01:57 PM
Porkie's Avatar
Porkie
why dont you like the rev limiter on the engine mark? is it hard on the engine? why do you keep reving so high rod? honest questions
Old Aug 28, 2012 | 04:03 PM
zippyobrien
I assume the sudden loss of fuel or spark puts massive stress on a already high stress engine.
Seen plenty of engines chuck a rod when hitting the limiter.
Old Aug 28, 2012 | 05:18 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Because i drive it hard Lee. On all other engines ive had its easy to tell when to change cos the Power starts to die. This Bl**dy thing has a billion horsepower everywhere & its so easy to over rev it. Dont mean to be using those revs its just through the rev range so quickly in 2nd & 3rd. On my gearing 8.9k is 98mph in 2nd & 142mph in 3rd so lots of fun to be had on the street . Its also 190mph in 4th & oh so easy to reach .
Old Aug 28, 2012 | 06:46 PM
Mark Shead's Avatar
Mark Shead
Correct, Also I didnt know Rod was abusing the engine so much so will make some changes to the mapping to drop the power over 8.5k.
Mark
Old Aug 28, 2012 | 06:48 PM
Mark Shead's Avatar
Mark Shead
Replied, I will also start to fine Rod Ł100 for every 50rpm past 8.5k
Mark
Old Aug 28, 2012 | 08:16 PM
wes's Avatar
wes
Mark
I can imagine the ignition map now:
load 390kpa, 8500 RPM = 15 degrees*
load 390kpa, 8750 RPM = 1 degree
(*Wild stab at the ignition timing on this engine)
Old Aug 28, 2012 | 08:20 PM
Mark Shead's Avatar
Mark Shead
And watch the EGT go through the roof, It will have a bit more createtivety than that.
Mark
Old Aug 28, 2012 | 08:28 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Fuel cut will sort that.
Old Aug 28, 2012 | 09:27 PM
wes's Avatar
wes
Mark
I wasn't implying that ignition would be the / only change Mark, just an off the cuff comment on my part that i didn't think through
As peak EGT's occur around stoich and going richer OR leaner at this point will reduce EGT's?
Old Aug 29, 2012 | 06:38 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
complete fuel cut means no heat generated, only cooler air drawn through the cylinders.
a complete ignition cut means over fuelling, pops and bangs at turbo, but more cooling of cylinders and valves. car will run lumpy straight after the cut due to excess fuel floating about, but recovers quickly.
Old Aug 29, 2012 | 04:28 PM
Ginge's Avatar
Ginge
www.virtualseason.net
Heres the bit.
Newbury bypass Rod, that's just near me. Next time your off for a jolly round there pick me up would you
Ginge
Old Aug 29, 2012 | 06:04 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Ginge
Rod rules the Newbury road lol I've seen over 160 with him at the wheel with a lot less power
Old Aug 29, 2012 | 06:30 PM
polly_x's Avatar
polly_x
Impressive to some...............
Old Aug 29, 2012 | 06:33 PM
ajamesc's Avatar
ajamesc
To right and I'll agree not all! But I'm into fast well handling cars so I am but every one has there own likes and dis likes just as they do opinions
Old Aug 29, 2012 | 06:39 PM
stevenr's Avatar
stevenr
I think polly was referring to the fact it was done on a public road,not very impressive at all and someone his age should know better.
Old Aug 29, 2012 | 06:44 PM
ajamesc's Avatar
ajamesc
Without meaning to sound funny a lot of people sit on there high horse and judge about things like that but also do the same! Why would you mod/tune a road car if your not going to on the odd occation use it! Now I'm not saying its right or that I myself always drive like that but it dose happen
polly_x's Avatar
polly_x
We all speed to some degree i know, but bragging that kinda speed in public is not cool in my opinion.
Old Aug 29, 2012 | 06:47 PM
ajamesc's Avatar
ajamesc
I best not tell you I now know my gsxr will do over 170 on the ring road then lol
Old Aug 29, 2012 | 06:53 PM
stevenr's Avatar
stevenr
I know it happens,i'm no angel myself but i certainly wouldn't dream about travelling at that speed on a public road.I'm not bothered about myself but i'd hate to take someone else's life.
Each to their own though.
Old Aug 29, 2012 | 07:11 PM
stevieturbo
C**t
It's one thing doing such speeds etc. But admitting it on a public forum is where the stupidity would lie.
It's the sort of thing that could come back to bite one day. Never admit anything like that on a public forum, as it is there for all to see, for a very long time.
Old Aug 29, 2012 | 07:15 PM
polly_x's Avatar
polly_x
Yep, was my point Stevie. I doubt Rod is too happy that people are doing it on his behalf either.
You are effectively bragging about doing something that could land you in prison for while in public. I doubt you would come on here telling people about how you mugged an old lady on the ring road or burgled a house.
Old Aug 29, 2012 | 07:21 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Aww boo hoo someone reported my posts, butthurt much? Not allowed to post a picture but allowed to brag about breaking the law? Good to see people have their priorities right.
stevieturbo
C**t
TBH if they did, nothing would ever happen lol
They'd hunt down a motorist far quicker than a criminal ! And probably jail one quicker too.
Old Aug 29, 2012 | 07:23 PM
polly_x's Avatar
polly_x
Agreed!
Old Aug 29, 2012 | 07:25 PM
ajamesc's Avatar
ajamesc
I'm not being funny but it would hardly stand up in court would it! It's not like I've just put a video up with my reg number and face pic in it is it
Old Aug 29, 2012 | 07:28 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Erm, it probably would actually.
Old Aug 29, 2012 | 07:29 PM
polly_x's Avatar
polly_x
Who knows......Its still not cool to admit in public regardless of it can be used as evidence against you IMO.
Like I said, you are bragging about something that could put you in jail!!!
Old Aug 29, 2012 | 07:32 PM
ajamesc's Avatar
ajamesc
Really what here say off an Internet sight what's to say I haven't made it all up lol I'll pm you my name and address and you can report it tomorrow and we can see how far it go's
Old Aug 29, 2012 | 07:44 PM
BigChuck's Avatar
BigChuck
if the police were investigating.
they have your reg number, its in your avatar
they have your name and address
they can tell the location of where you made that comment,
plus and admission of guilt.
now they may not be able to pin point a specific crime, but if you were involved in something serious, this is all evidence that could be used against you.
Old Aug 29, 2012 | 07:47 PM
polly_x's Avatar
polly_x
The passionford grammar and spelling police will be along in a minute to bang you up with posts like that!
Old Aug 29, 2012 | 07:53 PM
ajamesc's Avatar
ajamesc
Would not stand up I've had the police knock on the door before as I don't get on with the niegbours. Anyway they rang up complaining I ride to fast and I wheelie all the time which is not true as I dont ride like an idiot by my house but may of on the odd ocation been a bit silly! And of course I was worried as they where on the door step but there wasent any thing they was able to do as there was no evidence all they could say was there had been a complaint made and I should be aware plus gave me the they don't won't to be called out to see me liein on the side of the road which was fair enough
Old Aug 29, 2012 | 07:55 PM
ajamesc's Avatar
ajamesc
O yes you can count on that! I'm very surprised zetec Sam has not already started pmsl
