bearing/bush removal
Old Aug 25, 2012 | 07:01 PM
GAZ345's Avatar
GAZ345
Default bearing/bush removal
need to buy a bearing/bush removal kit for a press,don't want to spend fortunes as it's not something i will use everday,are the ebay ones okay or am i better spending on better brand,what do you recommend
Old Aug 25, 2012 | 08:28 PM
Brendan's Avatar
Brendan
struggling with reality
surely all you need is a set of drifts? have improvised mine and they work fine! also the set of steel cylinders from my clutch alignment tool works well!
Old Aug 25, 2012 | 08:32 PM
whizzisat114's Avatar
whizzisat114
Last bushes I had to remove from cossie rear arms I used 3/4 inch sockets in a big vice
Just chop one side off to make it easier to push put
Old Aug 25, 2012 | 08:39 PM
GAZ345's Avatar
GAZ345
i tried a socket that just seemed to splay the bush out making it worse
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
