storing a car outside for the winter! any tips?
Old Aug 24, 2012 | 12:08 PM
philg12's Avatar
philg12
Default storing a car outside for the winter! any tips?
im taking my car off the road for 6 months at the end of october but dont have a garage to keep it in so will have to be outside on my driveway!
is there any tips you can give me?
plus how do you stop the interior from becoming mouldy?
Old Aug 24, 2012 | 12:20 PM
STeve's Avatar
Super Moderator
its a tuff one all I can say is if you cover it up make sure you get a very decent cover as the cheaper ones hold moisture and in icy weather etc stick to the cars paintwork causing damage, My sons has been under cover for near on 2 years outside, and his still smells fresh inside with no mould and just rust on the discs etc
Old Aug 24, 2012 | 12:32 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Id say dont use a cover as they do more harm than good! the car will get very damp and never dry out. I had one but would never use another! and mine cost 160 lol it was an all singing all dancing breathable one. Even when it had dryed out and the weather was ok the car was still very wet under the cover
Old Aug 24, 2012 | 12:54 PM
Luca's Avatar
Luca
Lukesville
What car is it?
Old Aug 24, 2012 | 01:08 PM
Jeff Collision's Avatar
Jeff Collision
Protect your car from moisture. Keep it covered with a waterproof car cover. Mold is caused primarily by moisture, so you should keep interior of your car as dry as possible. Moreover, make sure that you car windows and doors are rolled up tightly to prevent moisture and debris from getting into your car.
Old Aug 24, 2012 | 01:11 PM
PileOfRust's Avatar
PileOfRust
Might be an idea to keep the car on axle stands too, so if it does snow the car will be off the ground, protecting tyres etc
Old Aug 24, 2012 | 01:28 PM
stu21t's Avatar
stu21t
If you can get a heavy duty tent/small marquee that would be best, i did see them in costco once for Ł60 but when i went back to get 1 theyd gone
That way the cars protected from the elements but loads of room to breath.
Old Aug 24, 2012 | 01:54 PM
big_wig_074's Avatar
big_wig_074
Couple of bags of dessicant inside should sort any moisture problems
Old Aug 24, 2012 | 02:06 PM
gingeRS's Avatar
gingeRS
if its only six months just leave it outside......why would you cover it?
make sure you have no leaks, thats what causes moisture and mould.
Old Aug 24, 2012 | 02:13 PM
mechanic28's Avatar
mechanic28
over inflate ya tyres,get a good cover and get some de humindifiers inside her,take the cover off once every month or so for a day and she will be fine
BigChuck's Avatar
BigChuck
forget covering it. iys only six months, get some of those moisture absorbing bags like the ones in trainer boxes etc. they should help keep the moisture down.
maybe extra air in tyres to prevent flat spots.
a good coat of wax over the paint work.
i wouldn't put it on axel stands, the car doesn't naturally sit like that and the suspension may not sit the same or have annoying squeaks when its back on the road
Old Aug 24, 2012 | 02:18 PM
SMILER258's Avatar
SMILER258
Id put it on some axle stands to keep the tyres from going lumpy. Or what ever its called. And if the cr is relatively new id keep it outside without a cover tbh. Should be fine. An put the battery on tricle charge
Old Aug 24, 2012 | 03:59 PM
philg12's Avatar
philg12
Originally Posted by Luca
What car is it?
its a fiesta st! iv got a corsa work van so taking it off the road for 6 months to save road tax and running costs etc etc!
might look into a heavy duty marque/tent if i can pick one up cheap enough!
do any of you have links to the car covers you used?
Old Aug 24, 2012 | 04:17 PM
Rsmat's Avatar
Rsmat
Best idea is find a rentable garage or a proper stair age place for six months... Not the exspensive and you have piece of mind.
Old Aug 24, 2012 | 05:22 PM
big_wig_074
yeah, its called dessicant, as stated earlier.
Old Aug 24, 2012 | 06:13 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Don't forget to disconnect the battery as well
Old Aug 24, 2012 | 09:37 PM
Brendan's Avatar
Brendan
struggling with reality
Ok ther the way to do this is to get the external car coon - the one with the battery trickle charger....
Dries you car out stops any shit getting anywhere near it and can now condition and top up the battery! They are the BEST!
http://www.carcoon.co.uk/outdoor-carcoon.html
I once kept my fiesta in one for 4 years!
Old Aug 25, 2012 | 08:24 AM
Just use it and use a steam cleaner to give it a wash down every week.
Old Aug 31, 2012 | 12:30 PM
philg12's Avatar
philg12
right found a company who does fitted quality car covers, heres the link if anybodys interested! lot of ford models listed!
http://www.carcarpets.co.uk/ford-121-c.asp
also looking at getting silica gel to trap any moisture! would a 500g bag be enough? or should i get a couple? also where should i place them?
Old Aug 31, 2012 | 12:52 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Not being funny mate, but a cover at less than Ł50 ain't goin' to be up to much....trust me. If you want a proper quality one, you'll need to pay for it
Old Aug 31, 2012 | 01:10 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
get a gallon of wd40 and spray it over, will come out fresh and shiney
to stop mould i usually us a kitchen disinfectant spray or wipes and give it a once over
Old Aug 31, 2012 | 03:17 PM
philg12's Avatar
philg12
yeah i know mate, thats the cheapest indoor one! once you select your car theirs more options, im getting the diamond outdoor waterproof one for Ł139!
Old Aug 31, 2012 | 06:12 PM
xr_craig's Avatar
xr_craig
I'd just leave it and maybe just wash it and take it round the block once a month or so
Old Aug 31, 2012 | 06:22 PM
ANDYRACER's Avatar
ANDYRACER
The more turbos,more fun!
I left my old skoda octavia vrs on my mates mums drive for 6 months, just started it every now and again and moved it forwards and back on the drive to stop the brakes seizing and tyre flat spots, also dont leave the handbrake on, leave it in gear.
A cover seems very drastic for a car that aint that old and is only been parked up for 6 months.
Old Aug 31, 2012 | 06:25 PM
Steve Escos's Avatar
Steve Escos
I used to keep my escos outside every winter. Good coat of wax and sealant. Very good cover that is breathable ( Company and technology I am involved in makes the nonwoven for the better covers). Fill the fuel tank full. Rotate the wheels every couple of weeks.
Old Aug 31, 2012 | 07:15 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Why it just rent a garage ?
Old Aug 31, 2012 | 07:21 PM
Mr S1's Avatar
Mr S1
Good man you gets what you pays for....
Old Sep 1, 2012 | 04:24 PM
philg12's Avatar
philg12
I live right on the edge of a forest so need a cover to stop the car getting covered in tree fallout and bird shit etc!
Should I blow up the types to maximum psi rated on the tyre wall? Or would I get away with going a bit higher?
Old Sep 1, 2012 | 06:52 PM
orionmojo's Avatar
orionmojo
If its only 6 months and on your drive just leave it. Wash it regularly and once a month start it and turn it round. That way any water traps will run off and nothing will sit too long in one place. Theres only ever 2 weeks of ice and snow really and standard maintenance applies then, correct tyre pressures, anti freeze etc.
Old Sep 1, 2012 | 07:58 PM
saph4be's Avatar
saph4be
I just have my cossie a good jet wash and polish cleaned it out and stuck some water absorbing pots from pound shop inside and started once a week and washed it when it got dirty, I also opened doors on a nice day to air it out snd had no problems!!
Old Sep 1, 2012 | 09:11 PM
RichieST's Avatar
RichieST
It's quite a new car, it it'll be fine. Just make sure it's got enough anti freeze in it, keep the tyres properly inflated, maybe take the battery off and keep it in the warm somewhere and forget about it.
original
Apr 28, 2026 05:20 PM
mk22door
49
Mar 26, 2022 07:15 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
muffster
Aug 12, 2015 08:14 PM
