Need yb conrods ..
Old Aug 24, 2012 | 06:40 AM
adriankt77's Avatar
adriankt77
Thumbs up Need yb conrods ..
After taking my yb rods to have new smallens bushes
I was told that the big ends are out of shape ( oval'd ) .
So nows perfect time to ' up rate' them .
I've been looking around and found these on eBay by a company called PPM
Item number 270493252498..
They look and sound the part but
Has anyone had any dealings with these ppl or no someone that has??
Any help would be appreciated
Old Aug 24, 2012 | 09:30 AM
Brendan's Avatar
Brendan
struggling with reality
sounds good but I would do a bit of research on the net, phone up the Australian maker and ask about recomendations from previous customers! I opted for carrillo rods in my with JE pistons!
Old Aug 24, 2012 | 09:36 AM
lacey's Avatar
lacey
Poly x on here has some shot peaned rods for sale
Old Aug 24, 2012 | 09:46 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
unless you are changing the rod ratio use std cosworth rods these were designed and manufactured by COSWORTH and have no horse power limitation on a yb as the rest of the engine will disintegrate first
the standard cosworth rod is a serious over engineered piece of kit
but what do cosworth know about engine design
there is nothing std about an original genuine cosworth part
you are more likely to be down grading by trying to upgrade
Old Aug 24, 2012 | 09:59 AM
adriankt77's Avatar
adriankt77
Cheers guys .
Tony I was planning to use my std rods but after
Taking them to be re bushed etc the machine shop
Said the big ends wer out of shape!
I no the std rods are very good and developed by
Cosworth and all the rest of it . I'm not changing
Cos I WANT to I'm changing cos I NEED to .
And was asking for help with choosing a decent set of rods..
Howard u getting on with my supra diff :-D
Old Aug 24, 2012 | 10:18 AM
Turbosystems
Super Moderator
just getting the brackets electro plated
why don't you just get a new set of genuine cosworth rods
very rare for the std rods to have any issues has your engine been suffering from detonation
Old Aug 24, 2012 | 11:11 AM
Derby_Gav's Avatar
Derby_Gav
Not been mapped by EP has it?!
Old Aug 24, 2012 | 11:17 AM
adriankt77's Avatar
adriankt77
Ok cool.. Do u no How long so I can get courier sorted ??
It's a 4x4 engine I bought about 2 yrs ago it's just been sat waiting for me to do something with it .. I had it taken apart an it had spun a big end at some point and scored the crank so had that a grind on big ends and mains so all nice an fresh .. If I could get hold of a good std set of Cossy rods for not much money then yeah I'd get std. ..
Old Aug 24, 2012 | 01:04 PM
Turbosystems
Super Moderator
4x4's are prone for spinning number 4 and a proper sump is a must
it is probably only number 4 rod that's out of shape
Old Aug 24, 2012 | 01:09 PM
richbogle's Avatar
richbogle
Mine spun number 4 few month ago the b*****d!!
Old Aug 24, 2012 | 01:14 PM
Turbosystems
Super Moderator
bet you wish you had invested in one of my sumps now
Old Aug 24, 2012 | 01:28 PM
richbogle's Avatar
richbogle
Lol tell me more??
Old Aug 24, 2012 | 01:45 PM
adriankt77's Avatar
adriankt77
Yeah tony it was number 4 that's the worst but all 4 are outta shape..
I have my sump all wrapped and ready for you . I'll send it with courier when he picks diff stuff up ok ..
Old Aug 24, 2012 | 01:47 PM
whizzisat114's Avatar
whizzisat114
Tony by proper sump do you mean big wing. Gated or both?
Is it worth running hp pump on 4×4's?
Old Aug 24, 2012 | 05:40 PM
LHD220Turbo's Avatar
LHD220Turbo
standard one is fine, no need for hp pump
Old Aug 25, 2012 | 12:22 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
just get the standard rods resized! its not rocket science for most machine shops... unless somehow they're big at the sides?
Old Aug 25, 2012 | 12:27 AM
RS2000CUSTOM's Avatar
RS2000CUSTOM
Regardless of what sump is fitted it is always No4 that is the most prone to failure
No4 is the furthest big end away from the oil pump and is the most likely to fail
If your oil pump sucks air (hence the need for dry sump or an efficient gated/baffled sump) then No 4 is gonna pay the price
Old Aug 25, 2012 | 12:28 AM
RS2000CUSTOM
HP/HC pump is useless if the pick-up pipe is in fresh air !
BRAM
Sep 8, 2015 07:11 AM
JamesA_RST
Oct 28, 2005 06:18 PM
silky16v
Aug 18, 2005 10:39 AM
raycov
Jun 11, 2005 06:48 AM
