Ecu tacho wire?
Old Aug 23, 2012 | 03:07 AM
RS Classics's Avatar
RS Classics
Default Ecu tacho wire?
Hi Guys
I have a shift light that only works with a ecu tacho signal, not a coil negative. Would anyone know where that is? or what pin on the ecu i should tap into?
Cheers guys
Old Aug 23, 2012 | 05:20 AM
VEEDUBBED's Avatar
VEEDUBBED
What ecu do you have?
If it's a Weber L8 you can get a signal off pin 7 on the ign. amp module.
If it's P8 some versions had a tach output off pin 7 or possibly pin 9 but i'm not 100% certain as within the same ecus the pins drove different things on different vehicles.
Old Aug 23, 2012 | 08:35 PM
RS Classics
Sorry i should have said, it is indeed a L8, so hook into pin 7? ill give that a shot tonight and let you know how i get on.
Old Aug 23, 2012 | 08:36 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
on another side while we talking about tachos.
my L8 loom (feeding a p8) has a tacho filter thingy. Can you get new ones when making a new loom? or can you get away with ditching it??
Old Aug 23, 2012 | 08:39 PM
costina's Avatar
costina
Live long and prosper!!
www.bigturbo.co.uk
Old Aug 23, 2012 | 09:03 PM
Psycho Warren
Carbon Crazy
none of those wiring diagrams show a tacho feed.
Old Aug 24, 2012 | 05:13 AM
VEEDUBBED's Avatar
VEEDUBBED
Yes, seeing as it's an L8 set-up connect the tach. wire directly onto pin 7 of the ign. amp, i did it on my non cos. turbo 16v twin cam 2.0 engine and it workes perfectly with the stock car ins. cluster's rev counter.
I wouldn't be too sure that it'd generate a proper signal for the shift light seeing as the amp. is also connected to the coil, try it out anyhow.
Let me know if it goes ok.
Old Aug 24, 2012 | 05:19 AM
VEEDUBBED's Avatar
VEEDUBBED
Warren, does the tacho actually work? or does the needle bounce about at idle?
Old Aug 24, 2012 | 02:35 PM
Psycho Warren
Carbon Crazy
my tacho works fine.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
griffo69
Oct 4, 2015 11:58 AM
IainRS1700T
Sep 25, 2015 06:44 AM
