ap brake size behind comps
Old Aug 22, 2012 | 06:39 PM
Mark RS's Avatar
Mark RS
Default ap brake size behind comps
does anyone know what is the bigest size of aps you can fit behind these wheels?
its on a 4x4 saph also what calipers 6 pots or 4 pots?
https://passionford.com/forum/alloy-...ith-tyres.html
Old Aug 22, 2012 | 07:19 PM
1374lee's Avatar
1374lee
As in my advert,I have ap 6 pot calipers and 330mm discs and there's plenty of clearance but I'm on 2wd as you know.
Thanks.Lee.
Old Aug 22, 2012 | 08:01 PM
The Youth.'s Avatar
The Youth.
defo 330 with ap 5200 4 pots or 6 pots not sure which number
steve
Old Aug 22, 2012 | 08:25 PM
Mark RS's Avatar
Mark RS
I'm looking to see if 330 is the biggest?
Old Aug 22, 2012 | 09:47 PM
stevieturbo's Avatar
stevieturbo
C**t
Ive 330mm on my car and they fit under 16" MO's
Old Aug 22, 2012 | 10:12 PM
Sonic Boom's Avatar
Sonic Boom
You will get 355mm discs with 7040's 6 pots as long as your prepared to shave the outside edge of the caliper down to the bolts.
That's only beacuse the spokes bend in, you can fit them behind without any trimming on old skool 5 spokes.
Rich
Old Aug 22, 2012 | 10:15 PM
stevieturbo
C**t
But whatever size will fit....dont overlook your spare wheel if you actually drive the car
Old Aug 23, 2012 | 06:10 AM
Mark RS's Avatar
Mark RS
The spare wheel doesn't fit as is lol
Old Aug 23, 2012 | 09:16 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
If its a 7.5x17 on a 4x4 then 343mm may be a possibility with 4 pots calipers. I will measure a wheel up when I get a mo but I'm pretty sure you wont get bigger in there.
Old Aug 23, 2012 | 10:47 AM
Mark RS's Avatar
Mark RS
Thanks Martin. Could I use 6 pots as already have them just want to go from 18s back to 17s and it could be a balls as I've 330 4pots on the rear. And 362 (I think) on the front with 6 pots
Old Aug 23, 2012 | 10:57 AM
Dingy's Avatar
Dingy
From my experience comps aint the same...
I have 4 sets of ML's in 15" and the clearance is different in every set.
Old Aug 23, 2012 | 11:30 AM
Martin-Hadland
If you have 7040 calipers then they're not going to fit, you'd be better off selling that kit to an Escos owner and fitting the rear brakes on the front and putting a 300mm kit on the rear.
Old Aug 23, 2012 | 11:35 AM
Martin-Hadland
You should try cleaning them some time, its probably pad material build up haha!
yatta
May 21, 2016 10:31 PM
Sp3no
Sep 27, 2015 07:23 PM
pabloXR
Sep 21, 2015 12:42 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
alexbarnes95
11
Sep 15, 2015 10:26 AM
