Cosworth HIGH Impedance injector Part Number?
Old Aug 20, 2012 | 05:34 PM
boXXer's Avatar
boXXer
GASH!
Default Cosworth HIGH Impedance injector Part Number?
does anyone have a part number for a injector that is HIGH impedance, and still fits the standard fuel rail setup? upto 350-400hp ish?
Im running emerald management so cant use Bosch Low injectors.
Siemans Deka's will do, but not sure on Part no.s.
Thanks!
Old Aug 20, 2012 | 06:32 PM
VEEDUBBED's Avatar
VEEDUBBED
You could try a set of injectors off a Fiat coupč 16v turbo, they're made by Weber, are around 385cc disc type and are high imp. around 13.9 Ohm at room temp.
I used them for ages on my 2.0 16v mill without issue.
Old Aug 20, 2012 | 07:15 PM
big_wig_074's Avatar
big_wig_074
They won't do anything like 350 bhp though!
Old Jul 8, 2017 | 09:30 PM
midnight_man's Avatar
midnight_man
guys, same problem.
I need high impedance injector for cossie...
400cc (ideal),..
are there any with direct fit?
Old Jul 10, 2017 | 09:35 PM
stevieturbo's Avatar
stevieturbo
C**t
There are hundreds. Cossie just uses a bog standard Bosch style fitment, 14mm o-rings etc.
They are without doubt the most common fitment. Old BMW,s Volvos, Fords, everything used to use that fitment.
Old Jul 11, 2017 | 04:21 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
I use these 630cc ones on my MG ZR with Pectel T2 management, they will also fit directly into a Cosworth with no mods as I used the higher capacity model on my RS500. http://www.siemensdeka.com/product/6...fi114961-60mm/
Old Jul 11, 2017 | 05:18 PM
Mark Shead's Avatar
Mark Shead
http://sasautocustoms.co.uk/bosch-pe...2lb-465cc.html
Old Jul 11, 2017 | 05:43 PM
Martin-Hadland
Have you used those Mark? I was tempted by them for my LS2 Chevy but found contradicting specs for them. The site below has them listed at 29lb/hr @ 3 bar
http://www.gomog.com/allmorgan/InjectorRatesBosch.html
Old Jul 11, 2017 | 06:29 PM
Mark Shead's Avatar
Mark Shead
Yes I have used them on 800bhp thread on here. 8 of them on a 500hp engine work very well.
Mark
Old Jul 11, 2017 | 06:33 PM
Martin-Hadland
Mark
Thanks for the info
Old Jul 11, 2017 | 06:58 PM
stevieturbo
C**t
Great injector, proven the world over thousands of times.
I've 16 of them lol
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
Aug 14, 2015 07:29 AM
