Daf mechanics - radio help please
Old Aug 20, 2012 | 08:30 AM
orionmojo's Avatar
orionmojo
Default Daf mechanics - radio help please
Any truck mechanics about that can help me please?
The radio in my 06 Daf 85 cf has stopped working, literally just wouldn't turn on one morning. I swapped the whole headunit out and still nothing so I got the multimeter out and had no power at the stereo, removed all my parrot kit too, still nothing. Got power at the relay in the fusebox but nothing at the headunit end. Is there a power inverter on these? I've taken the dash panel off and traced the wires ( I think ) to infront of the heater box and I didn't go any further. It's been broken for about 3 weeks now and im more than a bit bored of it tbh :-/ it's up for MOT next month anyhow but would like a bit of background noise before then I'm going slightly mad
Cheers. Joe
Old Aug 20, 2012 | 09:08 AM
big_wig_074's Avatar
big_wig_074
Check all the fuses, I had one go once and just went through the lot, found a blown fuse and it worked again, wasn't even labeled as radio, was a few years ago so can't remember exactly what, but have a look, might work
Old Aug 20, 2012 | 09:43 AM
orionmojo's Avatar
orionmojo
Yeah sorry forgot to mention that, checked for fuses but couldn't find a dedicated fuse, only a relay. Everything else is working though to my knowledge, cig lighter, beacons, work lights etc are all still fine.
Old Aug 20, 2012 | 10:02 AM
STeve's Avatar
Super Moderator
has to be a circuit protected
Old Aug 20, 2012 | 10:43 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i work for daf! is it a 12v or 24v radio? if its a 12v it will run through a dropper! there is a fuse for the radio that powers some thing else aswell look in the hand book
Old Aug 20, 2012 | 11:04 AM
orionmojo's Avatar
orionmojo
sure it's 12v, google Gave me that answer though and apparently in 08/09 They switched back to using 24v using blaupunkt units. Mine was a VDO until I switched it for a Sony cd player. Don't have a handbook and what's a protected circuit and what's a dropper? Is that the 24v- 12v inverter thingy?
Old Aug 20, 2012 | 11:20 AM
Carlos-Titx's Avatar
Carlos-Titx
Volt dropper, turns 24 to 12 mate. Be about the size of a packet of fags with heat sinks in it.
Old Aug 20, 2012 | 11:22 AM
Carlos-Titx
Along the lines of this Name:  84074623-00B6-447D-A356-817252C73992-26377-00001D22D0F9EEC4.jpg
Old Aug 20, 2012 | 11:24 AM
ajamesc's Avatar
ajamesc
Knowing daf I'd check lol plus if you have fitted a Sony that's more than likely a 12v! Id pull the radio and see if it is 12v if it is and you have seen it working the 24v singnal from the fuse bored will go to a voltage dropper so you can use a 12v radio. And from the top of my head it shares the same fuse as the cigar lighter
Old Aug 20, 2012 | 01:05 PM
orionmojo's Avatar
orionmojo
Cheers lads I had a quick look on my break, think I've found the voltage dropper behind the fuse board but I can't get to it lol. It's well hidden away. But it's something to check properly later when I park up for the day cheers
Old Aug 20, 2012 | 01:14 PM
ajamesc's Avatar
ajamesc
if its got 24v's into it but not 12v's out its fucked lol daf sell them in the trp book
Old May 10, 2015 | 10:45 AM
dehaulers's Avatar
dehaulers
Please I have a problem with my daf cf 65 automatic brainbox injector....it spins but does not start..power doesn't get to the nosle, I have changed filter, all electrical connections are in order, pls what possible locations do you think I can look@ do youthink the key might be bad as. A diagonist suggest the truck cannot decode the key censor, pls help me......my email is patoskybobo@yahoo.com.....tHanks
Old May 10, 2015 | 10:47 AM
ajamesc's Avatar
ajamesc
I'm not too sure what you trying to say mate? Are you saying it turns over but don't fire up or are you saying it's totally dead?
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
20/20 vision
Sep 29, 2015 11:27 AM
