360 vs 270 turbo bearing
Old Aug 18, 2012 | 08:50 AM
Cossy Mike's Avatar
Cossy Mike
Default 360 vs 270 turbo bearing
Can anyone explain what the advantage is please?
is it simply for more oil circulation?
if so can ANY Cosworth turbo accommodate it as a simple swap?
I'm referring to a stage 1 turbo technics T3 (S113)
Thanks
Old Aug 18, 2012 | 08:59 AM
daz1968's Avatar
daz1968
It is basically a thrust bearing in the turbo that normally covers approx 270 deg of the rotation and the centre housing is machined to accommodate a bearing that covers the full 360 deg of rotation. Only advantage is that it can handle more boost as I presume the load on the shaft is more evenly spread due to increased support. I have a s111 stage 2 hybrid on my car it's ideal for stage 1 or stage 3 chip
Old Aug 18, 2012 | 09:01 AM
GUZZLER's Avatar
GUZZLER
When the turbo comes on boost the shaft is 'thrusted' forwards, the load is put onto the thrust bearing (normally a thrust washer between the 2) a 360 bearing offers more support as the the load is spread over a bigger area, think of a 270 bearing as a pizza with a slice missing, 90 degrees of the support area is missing of there.
Some modern turbos have 360 bearings with big oil cut outs, this can cause premature wear.
rex647
Mar 6, 2022 06:20 AM
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
