MK2 Fiesta wiring in a 1.8 SLUG ECU with PATS
Old Aug 15, 2012 | 07:23 PM
xrt-mart's Avatar
xrt-mart
Default MK2 Fiesta wiring in a 1.8 SLUG ECU with PATS
Hi guys I bought a Escort 1.8 the other week to transplant the engine into my fiesta not realising it had PATS.
It was a R reg, with a SLUG ECU. I have removed the complete engine bay wiring loom and the loom from the PATS transponder>ECU (Un-cut), the transponder itself and 2x keys.
The PATS loom has a Oval connector with 2 wires going to it which would appear to be ignition live and permanent live? I assume the earth comes from the ECU?
Also do I need the time clock/LED for it to work?
Any help appreciated PM me if required as I know its a touchy subject.
Mart
Old Aug 16, 2012 | 08:06 AM
Brendan's Avatar
Brendan
struggling with reality
where are you located ?
Old Aug 16, 2012 | 08:10 AM
snoopaloopa's Avatar
snoopaloopa
You dont need the clock/led its just nice to have so you can read any pats codes that occur, otherwise you have everything you need really
Old Aug 17, 2012 | 06:08 PM
xrt-mart's Avatar
xrt-mart
I'm based in Crewe
OK so I know I have everything, but is the wiring the same as per any zetec conversion on the 10 pin connector? and I assume there are only 2 extra that go into another oval type connector underneath the steering column, they look like they go to the fuse box so must be power supplies I'm guessing 1 permanent and 1 ignition?
Mart
Old Jan 9, 2016 | 01:57 PM
jjamesclark's Avatar
jjamesclark
how did you wire this up
big_Rad
Sep 15, 2017 09:36 AM
Porplus12
Sep 10, 2015 07:20 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
gingerturbo
Aug 11, 2015 09:44 PM
knight19770
Aug 4, 2015 12:36 PM
