Airtec throttle bracket
Old Aug 14, 2012 | 04:13 PM
BRAMMER's Avatar
BRAMMER
Default Airtec throttle bracket
Has anyone on here used one?
I've recently fitted one and it just doesn't seem right with the standard cable
It's either the cable is wrong for this setup or me being stupid but i have been trying to set the throttle position sensor and i can get the 0.35v on closed throttle but can't get anywhere near the recommended open throttle figure i'm struggling around 3.75v which isn't enough due to the throttle not getting full lift as i'm after 4.5v+.
With the throttle fully open 3.09v the spring is completely compressed to max and the reading is in the video.
The picture below is with the throttle cable removed
Also does anyone know what size O ring the inlet to throttle is as i want to change that as it's started ticking over at 1500rpm and then rising when hot so points to air leak and the Cometic gasket has been used a few times now.
Old Aug 15, 2012 | 05:59 AM
Ron has one on his ,i fitted one to steves mk2 fiesta cossie the other day using the standard cable ,all fine
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Russ Payne
Sep 25, 2015 08:29 PM
