What power will a GT28 give on a fettled yb ?
I fancy a gt30 but am only looking for 450 bhp ish , currently have a r/b t38 but am looking for more driveability. Or am I better staying with what I have ?
The gt3071 is a good choice, you gain a small amount down the bottom, a bit of mid range torque and a bit of power up top, all round a better turbo
I wouldn't go gtx though personally
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
To do 450bhp on a GT28 series you'd have to go for the GT2876R IMO. The compressor map suggests it will support it and the good news is that they run an Inconel exhaust wheel which lends itself nicely to your ALS/LC! I've not personally experienced one back to back with a RB T38 on a YB so can't comment on the drivability, but if its anything like the GT2860RS, it will need a custom oil return to work with the 4WD manifold.
I havnt had much experience with the big gt28 kev, although I'm led to beleive the biggest gt28 runs the gt3071 comp wheel with a smaller exhaust wheel, which IMO isn't a great idea, the gt3071 exhaust wheel is suited perfectly to its comp wheel.
Powers fine uncle Pete, thinking more of how it's delivered tbh.
Sorry mate,soon .
gt3071r will be a good choice, i've just fitted one to my zetec turbo engine, pulls very well indeed, not particularly laggy either.
next up would be a gtx3076r, about the same lag, but more power.
gt28 would be struggling up at 450bhp
Have you had any experience with the ftx3076?
There's a big jump in lag between a gt3071 and a gtx3076, the latter is a 600bhp turbo!
however the gt3076 is only marginally laggier than the gt3071r, so one would assume given the lower lag on a gtx wheel will overcome this and give great improvement on power.
the gtx3076r is only a 600bhp turbo when you're at 2.5BAR though, at 2BAR it's more of a 500bhp turbo.
exhaust housing plays a big part too, so that needs to be a factor too.
At 2.2 bar boost it is 590/600bhp turbo, (on a tial exhaut housing which drastically improves back pressure)
Johnny it's not just the Audi world, I don't rate the gtx turbos all that highly with the work we have done with them, deffinately better turbos out there.
Kev you should see Iain to get a shot in my old car , it is similar spec to yours but with slightly lower comp. I was very impressed with the GT3071 it spooled better than my old T34.
I got mine from Vince at CR Turbos Kev.
The one I had used a machined out .63 style cosworth exhaust housing so it was a straight bolt on as far as exhaust goes. It isnt the best as far as back pressure but since I wasnt planning on doing alot of top speed or track work I worked out well for me.
not sure if the gt28 will take you to 450hp. on my engine (3sgte) there only good for 350-400 iirc. have a word with tim bill at tb developments as he is a uk supplier
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mc5506
Oct 5, 2015 09:57 PM
SMILER258
Sep 28, 2015 09:04 AM
