Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
MT75 4x4 gearbox dohnut prop section
Old Aug 1, 2012 | 08:12 PM
M K's Avatar
M K
Default MT75 4x4 gearbox dohnut prop section
Hi
I am after a mt75 4x4 gearbox short prop section like this in the photo with the long metal shaft sticking out the end that goes into the dohnut bearing
But the 3 holes need to be 90mm apart!
The one I bought does not fit my dohnut as the holes are only 83mm apart as you can see here and i did not realise there was a difference between the different cossies
So i am looking for 1 that has the long metal nose to go into the dohnut bearing and the holes 90mm apart if anyone can help
Thanks
Marc
Old Aug 8, 2012 | 10:57 PM
markk's Avatar
markk
Id say its the donut thats splayed not the prop pal, im sure i have one of them, i will measure i for you
Old Aug 9, 2012 | 04:53 AM
M K's Avatar
M K
You mean it could just be out of shape? Didn't think of that, maybe il try squeezing it in to fit the bolts
Old Aug 9, 2012 | 05:55 AM
dojj's Avatar
dojj
Resident Wrestling Legend
It's out of shape is all
They used the same doughnuts across the board
Old Aug 9, 2012 | 06:19 AM
cossie330's Avatar
cossie330
Thats how my replacement was too, I used a large jubilee clip round it to reform it whilst fitting then removed clip once fitted to prop
Old Aug 9, 2012 | 07:11 AM
markk's Avatar
markk
They used to come with a metal band round them when new, it will fit.
Old Aug 9, 2012 | 07:19 AM
M K's Avatar
M K
Ah well that makes me look stupid lol
I thought I bought it all bolted together but had a few other gearbox prop pieces back then as it was over a year ago, I thought I must of sold the one I needed and powder coated the wrong one
Thanks for your help guys
Marc
Old Aug 13, 2012 | 06:44 AM
M K's Avatar
M K
Thanks for the help guys got it fitted yesterday
Old Aug 13, 2012 | 12:28 PM
dojj's Avatar
dojj
don't bend the bolts when you tighten them up, they seem to have a habit of doing that if you are using the normal ford arrangement
rog
Sep 16, 2015 03:00 PM
3doorcozmess
Sep 15, 2015 06:06 PM
tib2220
Sep 14, 2015 12:33 PM
Adam Graham
Sep 6, 2015 06:04 AM
