what would sierra cosworth mk1 lights be worth?
Old Jul 17, 2012 | 05:37 PM
paceo's Avatar
paceo
Question what would sierra cosworth mk1 lights be worth?
dropped the cibie light today didnt i!! only from like 2 inches and the lens smashed! but i see you can buy new lenses. the other light is lucas. from the mk1. reflector lights are real and not dummys. maybe one good one can be made out of the two!
one looks bigger than the other but its just the camera angle both same size.
Old Jul 17, 2012 | 10:21 PM
tonysierra4x4's Avatar
tonysierra4x4
the lights are interchangeable so could make one out of two. i bought both lucas with case in good cond and cibie with a cracked casing. to change you need to swap the adjusters as they are different. can't remember which is what colour but one has white threaded and the other has black threaded adjusters. hope this helps.
Old Jul 19, 2012 | 01:14 PM
paceo's Avatar
paceo
what would they be worth? theres a plastic bracket snapped on one of the on the rear as you can see. will stick them on ebay! but want to know what to start them at?
Old Jul 19, 2012 | 07:17 PM
tonysierra4x4
wouldn't have a clue on value. most people want good condition headlights but as long as reflecters are ok maybe of some use to someone. try £5 or £10 and see what happens. postage is quite high on headlights so with this cost on top may not be viable. i would certainly remove broken glass to cut down on weight for posting. by the time you pay ebay and paypal fees you won't get a lot.
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
Old ford
Jul 31, 2015 06:50 AM
