Cossie power steering stiff
Old Mar 29, 2012 | 07:21 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Cossie power steering stiff
Fitted new pump and rack,was ok for about 3 miles then went stiff when stationary. Bled it a bit and it's free now but screams when turning and revs are above 2000 rpm, any fooling ideas ?
Old Mar 29, 2012 | 07:36 PM
paul16v's Avatar
paul16v
Monte 087
Have you had the bottom pulley off for any reason?
Old Mar 29, 2012 | 07:51 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Ive just had this on mine after putting it back togther after having the pump off for a while! With mine it was the pump not pressurising the oil so i took the pump apart and all the little vains where stuck i cleaned every thing up oiled it and now its fine! also managed to kink the high pressure pipe that go's from the pump to the rack so had to cut that out and braze in a new section as there was no way i was paying 40 quid for a second hand one!
Old Mar 29, 2012 | 08:08 PM
KSA-Cossie's Avatar
KSA-Cossie
No mate
Old Mar 29, 2012 | 08:09 PM
KSA-Cossie's Avatar
KSA-Cossie
Pump is giving plenty pressure , it's fine sitting idling, not so fine when driving cos of the noise lol.
Old Mar 29, 2012 | 08:14 PM
ajamesc's Avatar
ajamesc
Arr right i only read the title which was steering stiff
Old Mar 29, 2012 | 08:26 PM
Rsmat's Avatar
Rsmat
Usually when they scream there short of fluid mate.
Old Mar 29, 2012 | 08:29 PM
KSA-Cossie's Avatar
KSA-Cossie
Loads of fluid in it Matt, gonna try a new belt and bleed it some more. When are you going to MSD for your mapping ? I'm dropping mine off on Saturday.
Old Mar 29, 2012 | 08:30 PM
KSA-Cossie's Avatar
KSA-Cossie
Thanks for the reply though James.
Old Mar 29, 2012 | 09:17 PM
Rsmat's Avatar
Rsmat
10th of April mate.
Old Mar 29, 2012 | 09:56 PM
Csm's Avatar
Csm
Some power steerings can be a cunt to get the fluid round, get constantly turning the steering left to right on the spot
Old Mar 30, 2012 | 06:19 AM
KSA-Cossie's Avatar
KSA-Cossie
Gonna try bleeding it more tonight.
Old Mar 30, 2012 | 06:39 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Your just a wimp
I didn't know you could even bleed the PAS Kev
Hope you fix it and all goes well with the mapping
Steve
Old Mar 30, 2012 | 06:43 AM
KSA-Cossie's Avatar
KSA-Cossie
Originally Posted by cossie4i_
Your just a wimp
Steve
Every day is a school day Steve lol cheers mate.
Old Mar 30, 2012 | 01:04 PM
ajamesc's Avatar
ajamesc
Bleed it with the front wheels in the air so the oil will pass through the rack without the weight of the car against it
Old Mar 30, 2012 | 01:29 PM
gibbo frst's Avatar
gibbo frst
ive always just had the front wheels off the floor and turned lock to lock a few times... the fluid i put in their once caused it to squeel so drained it out and put the cheap motor factors stuff in and never been a problem.. the cheaper stuff looked a lot thicker ..
turbotrev
14
Sep 27, 2015 10:44 AM
gcfcos
24
Sep 21, 2015 04:26 PM
DHMC
Ford Fiesta
Sep 20, 2015 06:47 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
