Fitting Focus RS box in Series 2
Old Mar 25, 2012 | 09:19 PM
TomPengelly's Avatar
TomPengelly
Kapow!!
Default Fitting Focus RS box in Series 2
Im in the middle of building my escort rs turbo. The 2 litre zetec is built, the brackets are welded on the inner wing to take the mtx75 box. Today i bolted the engine and gearbox together and fitted it in the car, so the engine mount and top gearbox mount are holding it in, just need to make a bracket for the bottom rear gearbox mount.
It looks like i have welded the top gearbox mount bracket too far forward. I have taken the engine mount off again and supported the engine on a jack. When i move the cambelt end forward so the engine looks straight with the front panel, theres no way my focus rs manifold and standard gt25 will fit without touching the radiator. Tomorow i will try and move the rad as far forward as i can, if this still doesnt work, i might try mounting it in front of the front panel? But by the time the intercooler and fans are on too, i dont think the bumper would fit?
The only other thing i could do is fit one of those manifolds where the turbo sits above the gearbox? Whats your opinions people? My engine is capable of 380ish bhp, its just the focus rs msnifold and turbo thats restricting it. But didnt really want to keep throwing money at it, and i got a gt25 and manifold cheap.
Any advise on what to do? Thanks in advance!
Old Mar 25, 2012 | 09:44 PM
nevsrevs's Avatar
nevsrevs
move it as far forward as poss mate, its been done alot of times in your shell, dont give up on the log manifold and gt25, its such a good set up, ask crazy cage what he thinks, he knows his onions when it comes to mount and mtx75
Old Mar 26, 2012 | 05:57 PM
crazycage's Avatar
crazycage
post a pic from overhead please.
Old Mar 26, 2012 | 08:53 PM
TomPengelly
Kapow!!
Old Mar 26, 2012 | 08:54 PM
TomPengelly
Kapow!!
That is a photo of the turbo next to the intercooler. the radiator still has to go inbetween them...
Old Mar 26, 2012 | 09:02 PM
Danster76's Avatar
Danster76
Tom, on my setup my rad sits bang on that bolt on the crossmember, fan, then intercooler and bumper fits ok. From your picture it looks like if you positioned your rad in the same place then you would have clearance.
Old Mar 26, 2012 | 09:13 PM
TomPengelly
Kapow!!
Hi Dan, ahh ok il try it that way round then. but my fans are quite thick, might be worth trying a slimmer set like yours.
Old Mar 26, 2012 | 09:18 PM
TomPengelly
Kapow!!
My rad is quite thick too.
Old Mar 26, 2012 | 09:20 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
i had to move my rad forward 2" to get my turbo in
Old Mar 26, 2012 | 09:21 PM
clarke5700's Avatar
clarke5700
Old Mar 26, 2012 | 09:22 PM
clarke5700's Avatar
clarke5700
alltho in a mk2 fiesta but the idear is the same
Old Mar 26, 2012 | 09:41 PM
TomPengelly
Kapow!!
ah ok cheers mate. do you run a fan?
Old Mar 28, 2012 | 06:50 PM
TomPengelly
Kapow!!
Any ideas anyone? Think i gotta modify the brackets so the engine sits square i spose!
Old Mar 29, 2012 | 04:45 PM
crazycage's Avatar
crazycage
cut them off and reweld them , its that or space the engine side out but like you said you dont have the space.
Old Mar 29, 2012 | 05:32 PM
Gadget's Avatar
Gadget
Spanner monkey
As above, if you've welded it to far forward, Lop it off and weld it back in where you need it. I would.
Old Mar 29, 2012 | 09:06 PM
TomPengelly
Kapow!!
Yeah thats what im going to do. When the top mount is sorted, and the engine is level and straight, any idea how to attach the bottom / rear mount? Cheers
Old Mar 29, 2012 | 09:34 PM
Rick's Avatar
Rick
crazycage does a much neater mount than the one you have now, plus the rear mount.
Rick
Old Mar 29, 2012 | 09:52 PM
TomPengelly
Kapow!!
Crazy cage - do you have any photos of a rear one you do? Ive modified the ally bracket that bolts to the box so the engine is now level and straight! Just the rear one to do. Might also uprate the top mount too.
Old Mar 29, 2012 | 10:29 PM
clarke5700's Avatar
clarke5700
crazy cages mount highly recommend it
Old Mar 29, 2012 | 10:30 PM
clarke5700's Avatar
clarke5700
Old Mar 29, 2012 | 10:31 PM
clarke5700's Avatar
clarke5700
and this is how i made my back mount
Old Mar 30, 2012 | 07:42 AM
Rick's Avatar
Rick
PM him mate
neil18
Mar 14, 2016 01:08 PM
track.focus'd
Aug 12, 2015 05:53 PM
