Wiring lambda help
Old Mar 25, 2012 | 03:24 PM
Rsmat's Avatar
Rsmat
Default Wiring lambda help
Basically fitted lambda in exhaust and ran the wiring from it along the bulk head... Here the wires ....
And it comes with this plug as standard...
So the question being... As anyone else used this plug and if so how do I do it...?
Cheers Mat.
Old Mar 25, 2012 | 03:29 PM
Come on Mat your battert tray is dirty lol.
if you get stuck pm Will pedley mine has got the same plug on as that.
It looks like there is 2 wires there should/is there 3 or 4.
Old Mar 25, 2012 | 03:32 PM
Turbosimpsons's Avatar
Turbosimpsons
Do you just want to know how to put the plug on or wire the lambda
Old Mar 25, 2012 | 03:36 PM
Rsmat's Avatar
Rsmat
Battery tray has copper grease on mate so it doesn't rot or rub... And there is 3 wires mate just how I took the pic.
Both please mate.
Old Mar 25, 2012 | 05:10 PM
Rsmat's Avatar
Rsmat
Anybody..?
Old Mar 25, 2012 | 05:18 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Mat,
The plug allows you to join the 3 wires on your lambda sensor to the 3 wires i'm about to talk you through. It basically allows you to crimp the wires together rather than soldering so as not to interfere with the voltage readings.
The yellow bits in there are moisture seals. The long grey bits have two bits that unscrew.
Feed your wire through the black plastic casing, then put a moisture seal on, then unscrew one side of the grey barrel and slide that on. Strip a bit of the wire back so there is a bare end, then tuck that in to make contact with the metal bit of the main section of the barrel. Screw together to form a tight joint. Repeat on the other side making sure you keep the black wire in the right place. The white wires don't have a polarity.
One of the white wires needs to go to a switched ignition power source such as the ECU relay.
The other white wire needs to go to a good clean ground.
The black wire needs to go to Pin 2 of the ECU connector. (I say Pin 2 purely from memory - please check to confirm!)
The two white wires form a heater circuit and the black provides the switching voltage signal into the ECU.
Hope that helps
Old Mar 25, 2012 | 05:21 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
it is pin 2 will
Old Mar 25, 2012 | 05:23 PM
Big Will_'s Avatar
Big Will_
Originally Posted by prius
it is pin 2 will
My memory hasn't faded in the last 3 years afterall!
Old Mar 25, 2012 | 05:39 PM
Rsmat's Avatar
Rsmat
Will your a diamond mate..!!!
Old Mar 25, 2012 | 05:41 PM
Rsmat's Avatar
Rsmat
Infanct Will are you up Sheffield way anytime soon as I need some help with this... Been let down with local help.
Old Mar 25, 2012 | 05:43 PM
Will,s the man.
Old Mar 26, 2012 | 10:49 AM
Stu @ M Developments's Avatar
PassionFords Creator
Originally Posted by Will Pedley
One of the white wires needs to go to the fuel pump relay output so the lambda is only live with the engine running as it draws a lot of current and is actually cooled by exhuast gas.
The black wire needs to go to Pin 2 of the ECU connector. (I say Pin 2 as I have a good memory and ths is deffo correct)
Hope that helps
Memory Correction Insterted above....
Old Mar 26, 2012 | 10:54 AM
Big Will_'s Avatar
Big Will_
Thanks! It's been a while...
Old Mar 26, 2012 | 10:58 AM
No problem big fella, stop working so hard, your going to kill yourself.
Probably with a curry in a place that doesnt sell mango lassie LOL
Old Mar 26, 2012 | 11:00 AM
Big Will_'s Avatar
Big Will_
Haha. Never again will I do a demonstration of how you can eat really hot foodin an indian restaurant before checking that they do the one thing that remedies it!
Old Mar 26, 2012 | 11:20 AM
Was a scream mate. Good memories.
Old Mar 26, 2012 | 11:42 AM
Spiky's Avatar
Spiky
PMSL at that
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Si B
Sep 12, 2015 06:49 AM
