Pug 405 abs help
Right then chaps we have a 405 mi16v track car and it has a slight problem the abs light is on and were not sure what it is. Is there any way to test the sensors and relay?
Also when you turn the key the pump clicks 3 times is this normal?
Will the light just go out when the problem is fixed or do we need to do something to remove it?
